Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 06-03-2014 | 06:05 AM
  #2896
Originally Posted by justpoet
Depends on max amp draw of those servos. Add that together and compare to what the rx8 bec puts out to be safe. In practice, a servo seldom draws max amps as it is not usually at full load.
While I can't answer myself as I don't know of anyone currently running two servo's in electric...
I agree, but he also has Savox all over his sig which are notorious for absolutely excessive amp draw in comparison to other brands. In a lot of situations they're cheap, but you pay for it in other ways. I assume it's for mechanical brake, so you could be in a hard turn/brake at the same time probably stressing both a bit leading to some heavy draw.
I would recommend posting in the RX8g2 thread.
http://www.rctech.net/forum/electric...thread-56.html
RokleM is offline
Old 06-03-2014 | 07:39 AM
  #2897
Mizchief's Avatar
Thanks. I'm not planning on doing this anytime soon; I beat these things up too bad to add any additional complexity. Mostly considering for high-temp summertime racing and potentially to increase run time assuming the servo can do the breaking with less power. (not sure if that is true or significant)
Mizchief is offline
Old 06-03-2014 | 08:36 PM
  #2898
mydudrevo's Avatar
Does anyone know if Austin Blair has his NorCal set up posted anywhere? I'd like to give it a try but can't find it anywhere.
mydudrevo is offline
Old 06-04-2014 | 08:24 AM
  #2899
Originally Posted by spdrac430
what a blast first race with it and I made the A. All I need is some test and tune time and she will be awesome
Nice looking Truggy!!! Love the paint!
Finally got mine on the track for the first time at the Tiltyard opener over the weekend. Very impressed with the Handling, Jumping, Traction, and Stability of the truck! Its almost like cheating... I ran a Buggy Pinion and Ring gear in the front with 10, 7, 5 in the diffs. That worked very well and the truck just pulled all the way throughout the corner... I'm thinking of going 15 10 5 in the diffs next and keeping the Buggy pinion and ring gear in the front.
offroadlover is offline
Old 06-04-2014 | 04:20 PM
  #2900
justpoet's Avatar
I believe it was just testing in prep for the electric 8th nats. Look for a setup from there and you should see the same thing if you find it.
justpoet is offline
Old 06-04-2014 | 05:04 PM
  #2901
mydudrevo's Avatar
I can't find any of his et48 setups just the buggy and sc
I'm looking for the setup he was running in this video
http://m.youtube.com/watch?v=02GQRW-1Q6c
Old 06-05-2014 | 03:48 PM
  #2902
One Mile Up's Avatar
Just ordered my ET-48! I am super stoked to finally be able to play around on my local track with one of these!
I am in no hurry so I am just going to be placing orders here and there for the parts... but - my question to you all:
Is there any way to to easily differentiate whether or not I have a newer or older version of the truggy? I have seen the posts about the case screws being shorter than they should be - is this the best way to try and figure out the build date then?
I have been following the thread for 20 pages or so LoL...
p.s. If anyone cares - I got the kit from Stormer for $538.00 shipped!
One Mile Up is offline
Old 06-05-2014 | 07:33 PM
  #2903
cpt_RedBeard's Avatar
I believe Austin was no longer with the team at the time of truggy release, I wouldn't count on a setup existing. I know Mark Unrath has a pretty good setup, and my setup is about ready to share.
cpt_RedBeard is offline
Old 06-06-2014 | 02:58 PM
  #2904
teknorc's Avatar
There is only one version of the kit at this time.
teknorc is offline
Old 06-06-2014 | 04:03 PM
  #2905
Registered User
has any one got pics off the hobbywing 150 fitting in the et 48
TheMuffinman is offline
Old 06-06-2014 | 09:19 PM
  #2906
Take a look at page one of this thread.
iScream is offline
Old 06-09-2014 | 10:49 AM
  #2907
I am starting to look around for a motor/esc and battery set-up for my rig and I thought I'd check with you all since you guys have already been testing set-ups...
1. I am going to run the Tekin 1350kV and RX8 (Gen 2) combo for motor and esc.
2. I want a good set of 6S packs to run this... What would you all recommend for a good battery?
Keep in mind that this is my first electric r/c vehicle (since I was a kid), so I am trying to learn as much as I can as fast as I can!
Some guys tell me I should just get hard-case packs while others say it doesn't matter... I have no clue! LoL! I have looked at the SMC 6S hard-case packs and they seem pretty legit to me but I wanted to see what you guys had to say before I take the plunge on that big of a purchase!
Thank you in advance!
Old 06-09-2014 | 11:13 AM
  #2908
Matthew_Armeni's Avatar
SMC all the way! I've been slowly switching all my batteries to SMC, great performance at a great price. I'd go with the 4300 pack, it has the same energy density as the 4s 6500 packs so you'll make 10min for sure.
Matthew_Armeni is offline
Old 06-09-2014 | 01:06 PM
  #2909
boudin4evr's Avatar
thats what I run in my truggy, same tekin motor and esc with SMC 4300 6s
boudin4evr is offline
Old 06-09-2014 | 01:12 PM
  #2910
boudin4evr's Avatar
sweet! post close ups of your body
who painted it?
