Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 06-10-2014 | 09:43 PM
  #2926
R/C Tech Elite Member
Originally Posted by 8ight-e
6s setup for sale, Tekin t8 1350kv motor has 5 races on it, awesome shape and the lipo's are low use to new. LINK
I came really close to making you an offer on this before buying my ESC/motor new from amain. If your stuff was gen 2, I would have gone for it.
iScream is offline
Old 06-10-2014 | 10:00 PM
  #2927
8ight-e's Avatar
I'm not sure there is much difference.. I've been running 6s for a while, they were my top motor picks (t8's), I've seen a few people have issues w/ gen2 so I stayed with what I knew worked great.. On a positive note I have not seen any more g2 truggy/buggy motor issues recently. I did see another rx8 white give away the magic smoke this last weekend :P
8ight-e is offline
Old 06-11-2014 | 12:01 AM
  #2928
Originally Posted by One Mile Up
I am starting to look around for a motor/esc and battery set-up for my rig and I thought I'd check with you all since you guys have already been testing set-ups...
1. I am going to run the Tekin 1350kV and RX8 (Gen 2) combo for motor and esc.
2. I want a good set of 6S packs to run this... What would you all recommend for a good battery?
Keep in mind that this is my first electric r/c vehicle (since I was a kid), so I am trying to learn as much as I can as fast as I can!
Some guys tell me I should just get hard-case packs while others say it doesn't matter... I have no clue! LoL! I have looked at the SMC 6S hard-case packs and they seem pretty legit to me but I wanted to see what you guys had to say before I take the plunge on that big of a purchase!
Thank you in advance!
i use the same motor and after many incorrect lipo buys (3800 - 4400 mah) i realized its way too much run-time and i could also benefit from a weight saving, so after buying packs from 3000mah to about 3500 it was still too much, and now i exclusively use 2600mah gens ace 25-50c packs and they work great (12-14min runtime) and the weight is no more than 400grams...
just something to consider before you purchase your lipos, i wish i had someone to tell me this before i wasted $$$ on 6-7 lipos im probably no longer gonna use.
akshayp14 is offline
Old 06-11-2014 | 06:10 AM
  #2929
Originally Posted by mydudrevo
Your document is locked
I will fix this once I get home today but for now see this attachment.
munrath is offline
Old 06-11-2014 | 06:12 AM
  #2930
One Mile Up's Avatar
This is all GREAT info guys!
Keep it coming!
Thank You!
One Mile Up is offline
Old 06-11-2014 | 03:43 PM
  #2931
Is there a hidden gem I should know about before I order tires/rims? I need to get a couple sets to get going and wanted to ask you guys first!
Thanks!
  #2932
Here is the new working link to my setup...lol
https://drive.google.com/file/d/0B6D...it?usp=sharing
munrath is offline
Old 06-11-2014 | 04:59 PM
  #2933
Mav-07's Avatar
Hey man,
Are the gen ace your talking about 4s or 6s ??
Mav-07 is offline
Old 06-11-2014 | 07:46 PM
  #2934
Registered User
has anyone drive both the nt48 and the et 48 do they both drive the same and handle the same as I am looking at grabing both and when I need to switch from ep to nitro I just wanted to know the ??????
TheMuffinman is offline
Old 06-11-2014 | 08:25 PM
  #2935
I run both and they run very similar use same setup on both I think the nitro may even handle a touch better
scorpion51503 is offline
Old 06-11-2014 | 10:24 PM
  #2936
Mizchief's Avatar
Thanks!
I've been liking green hybrid pre-mounts for hard pack with pretty much any kind of dust conditions.
Mizchief is offline
Old 06-12-2014 | 07:18 AM
  #2937
wreckya's Avatar
The Hybrid is a JC tire right?
wreckya is offline
Old 06-12-2014 | 07:24 AM
  #2938
boudin4evr's Avatar
yes
if its loose and loamy dry subcultures is also a good JC tire
boudin4evr is offline
Old 06-12-2014 | 07:25 AM
  #2939
wreckya's Avatar
Hey guys this is my first jump into the Truggy's, I'm gonna be running pro-match 7600 mah 4s packs. Now on all my tenth scale stuff I run bullet plugs on my batteries, no one does that with these correct? And if so what's the most used plug, deans?
wreckya is offline
Old 06-12-2014 | 08:12 AM
  #2940
boudin4evr's Avatar
DO NOT go deans, any 5mm or greater bullet(solid not caged) style plug is best
like xt60, EC5, Castle's new green plugs, etc
Deans will work, but are a pain in the @$$
