Tekno ET48 Thread
#2896
I agree, but he also has Savox all over his sig which are notorious for absolutely excessive amp draw in comparison to other brands. In a lot of situations they're cheap, but you pay for it in other ways. I assume it's for mechanical brake, so you could be in a hard turn/brake at the same time probably stressing both a bit leading to some heavy draw.
I would recommend posting in the RX8g2 thread.
http://www.rctech.net/forum/electric...thread-56.html
#2897
Thanks. I'm not planning on doing this anytime soon; I beat these things up too bad to add any additional complexity. Mostly considering for high-temp summertime racing and potentially to increase run time assuming the servo can do the breaking with less power. (not sure if that is true or significant)
#2899
Finally got mine on the track for the first time at the Tiltyard opener over the weekend. Very impressed with the Handling, Jumping, Traction, and Stability of the truck! Its almost like cheating... I ran a Buggy Pinion and Ring gear in the front with 10, 7, 5 in the diffs. That worked very well and the truck just pulled all the way throughout the corner... I'm thinking of going 15 10 5 in the diffs next and keeping the Buggy pinion and ring gear in the front.
#2900
#2901
I can't find any of his et48 setups just the buggy and sc
I'm looking for the setup he was running in this video
http://m.youtube.com/watch?v=02GQRW-1Q6c
#2902
Just ordered my ET-48! I am super stoked to finally be able to play around on my local track with one of these!
I am in no hurry so I am just going to be placing orders here and there for the parts... but - my question to you all:
Is there any way to to easily differentiate whether or not I have a newer or older version of the truggy? I have seen the posts about the case screws being shorter than they should be - is this the best way to try and figure out the build date then?
I have been following the thread for 20 pages or so LoL...
p.s. If anyone cares - I got the kit from Stormer for $538.00 shipped!
#2903
#2904
#2907
I am starting to look around for a motor/esc and battery set-up for my rig and I thought I'd check with you all since you guys have already been testing set-ups...
1. I am going to run the Tekin 1350kV and RX8 (Gen 2) combo for motor and esc.
2. I want a good set of 6S packs to run this... What would you all recommend for a good battery?
Keep in mind that this is my first electric r/c vehicle (since I was a kid), so I am trying to learn as much as I can as fast as I can!
Some guys tell me I should just get hard-case packs while others say it doesn't matter... I have no clue! LoL! I have looked at the SMC 6S hard-case packs and they seem pretty legit to me but I wanted to see what you guys had to say before I take the plunge on that big of a purchase!
Thank you in advance!
#2908
#2910
38Likes
