Like Tree1Likes
RB Engine Thread
Old 05-05-2014 | 12:29 AM
  #451
Give it a name and it is exclusive? All engines are basicly the same (in disign) so you do not have to worry you will change a thing.
Roelof is offline
Old 05-05-2014 | 03:42 AM
  #452
choisan's Avatar
Understand that, but I think the odd size bearing is exclusive unless I can dremel out the little piece from the engine housing
choisan is offline
Old 05-05-2014 | 08:00 AM
  #453
I have seen that, the Novarossi Virtus has the same bearing. It is an expensive bearing and imo it is just to keep the support (no other bearing manufacturer is making these bearings so far I know). That is also why RB is using a different size crankpin.
Sad that RB is now also using these bearings....
As mentioned in the Novarossi topics, I would take out the edge in the crankcase so a normal bearing will fit when I am in the need of a new bearing.
Roelof is offline
Old 05-05-2014 | 10:22 AM
  #454
Default Replacing expensive bearing
Hello Roelof ,
To replace this special bearing do I need special tool or I can replace it like old school ? As I will receive it in few days for my virtus .
Thank you
Skem61 is offline
Old 05-05-2014 | 10:28 AM
  #455
Replacing it can be done in every same way you are used to do.
Roelof is offline
Old 05-05-2014 | 04:08 PM
  #456
choisan's Avatar
Thanks Roelof.
choisan is offline
Old 06-02-2014 | 04:32 PM
  #457
TeamCarnage's Avatar
I'm having trouble finding the answer. I have a R3 engine that needs a rod soon. Which Nova will work. Can't cross reference anywhere. tia
TeamCarnage is offline
Old 06-02-2014 | 05:07 PM
  #458
ToysRUsKid's Avatar
post in Uriah's thread.
ToysRUsKid is offline
Old 06-06-2014 | 01:51 AM
  #459
Hi all, can anyone give me any clue as to how good an engine an RB C10 is? I picked one up in a chassis an I can seem to find much about it anywhere. Good, bad? opinions please!
Fly'n Fish is offline
Old 06-12-2014 | 11:59 AM
  #460
JamesHealey's Avatar
Good 9 port Novarossi based engine, don't know how you will do for getting any spares for it these days probably at least a 4 year old engine.
If it's in good condition, run in properly and has good compression.
Should be an awesome engine!
JamesHealey is offline
Old 06-13-2014 | 12:12 PM
  #461
I have a C10 in my collection ..it's a very powerfull engine production date 2010.
This is a C10 engine from greek nationals 2010
http://www.youtube.com/watch?v=mItG-3V7BEc
tonyhalandri is offline
Old 08-21-2014 | 03:19 AM
  #462
Bundy_Bear's Avatar
Re: glow plug help!
My brother has an old RB Speedling Matrix (Sirio based). It came standard with a RB 01051-6 (CP-02 Series) turbo plug. Wondering if the newer 01052-6 (V3) is compatiable? Are all RB plugs re-badged Novarossi? I am kinda confused cause i knew Sirio had a different taper on it.... or was that Picco! :S
Thanks in advance!
Andrew
Bundy_Bear is offline
Old 10-08-2014 | 10:08 PM
  #463
ehames005's Avatar
This is probably a odd question for you guys but, will the RB speed .12 3 port engine be good in a off road Gas truck? Thanks
ehames005 is offline
Old 11-07-2014 | 03:36 PM
  #464
RB Products SPEED .21 Limited Edition 7-Port On-Road Engine
has anyone tried one of these engines?? and if what are the pros and cons of it..
DaRaceMasta is offline
Old 11-09-2014 | 09:35 PM
  #465
azeroth's Avatar
i have a speed 21 13 edition good power but i had some issues( possible owner malfuntion) but my speed .12 has 2 seasons and is going strong
azeroth is offline
