ORCAN
#91
True, there is no "cave" carved out left to right like on some egnines. Any idea why some do carve out a cave and others don't?
Of course, there is more space/volume in the case for fuel/air mixture, but that still does not answer why some do and some don't make a cave/enlargerd chamber.
In my oberservation the following modify this area to the maxiumum: Max Power, Capricorn and Mag
And the following do not: MH, Murnan, JP, IDM mods, Nova tuned, OS tuned. These guys do carve out/grind/polish the existing channels like in pic 14, but they do not carve out the whole chamber area left to right.
Fuel consupmtion could be one reason, max or optimum scavenging could be another -- but anyone got an more substantial ideas why some do and some don't do this? Lets hear them!
#92
#95
According to the write-up, ORCAN's new .21 RS7 is tuned for 16% fuel.
The engine comes with 0.4mm head shims.
If I were to run this engine on 25% fuel, do I need to increase the shims? If so, by how much?
Thanks in advance.
Sam
Thanks in advance.
Sam
#96
I asked the guy behind ORCAN and this is his reply
The RS7 is with 0.40 shims perfect for 25% nitro at sea level and also for 16% by 300m above sea level.
If they drive with 16% at sea level they can drive so, or can put 0.05 shim out maximum 0.10 so they have with 16% nearly the same power as with 25%
#97
Normally the higher from sea level the lower the head clearance or the more nitro you have to run. Your answer is telling otherwise......
#98
I will check.
"Put out" is not clear (add or remove) perhaps due to translation.
#101
The revs are so much higher can gear lower and ORCAN recommends changing the conrod and wrist pin after 3 liters on large tracks and 5 liters on small tracks! The engine uses the 7601 rod which has never been a long life rod.
Even though I am notoriously greedy when it comes to power the RS3 could have too much power and torque for some people. I am tempted to say it is too powerful for my taste, but I am still experimenting with ways to get more traction/less wheel spin and tuning the engine to make it more mellow.
You should try for yourself as the RS3 is a beast!! I need more time to say for sure. I love the GT3C and it has really served me well. I need more time to either get used to or figure how to better handle the RS3. My buddies are going to give it a try soon and we will see what their reaction is.
#102
The RS3 has more power and revs higher. I only have one liter through after break-in and race tune, but initial observations are that there is much more low end (I have to be very gentle out of corners), similar or a little less mid and then tons more top end. The RS3 is uses more fuel but is easier to tune and idles better than the GT3C.
#103
