Tekno SCT410 Thread
I was refering to the difference between the stock Tekno SCT410 chassis to the stock Tekno (lightened) EB-48 chassis. I changed the stock buggy chassis over to my SCT410 to see if any improvements could be made from the stock (non lightened Chassis) as I have the BCE T1 on my EB-48.
From what I've heard the EB chassis gives a little more flex than stock SCT chassis from the machining like the bec and of course lighter weight.
Can't hurt to try, free hand me down from the buugy is worth a try
C'mon, this isn't the Associated thread! We can be more helpful than "Check the manual".
To the OP:
If you put the 2 dots out on the rear it gives you 4 degrees toe out. If you look on the first post of this thread, there's a chart that will show you all the inserts and their settings.
To the OP:
o I had to look at the buggy manual to find what degree the hinge pin inserts (aka, pills) were for toe or sweep. Info about the double dot is not in my sct410 manual.
I just love it when people take the time to type "Look it up. The info is in the previous 20000 posts." Rather than just give an answer.
And as I've posted before, the patience and helpfulness of everyone in this thread goes above and beyond. Much appreciated, especially for newbs who are searching for answers and advice.
I don't think he meant anything by it, probably the old teaching someone how to fish instead of giving him a fish... but it was a fail because its not in the sct manual
My truck did not come with the 2 dot pills and I will grab some on my next order if I can figure out what group of parts they come in... I'm guessing a EB part, not a SCT part.
Would like to have the finer adjustment they seem to give. It's a half step of the 1 dots from what I can tell.
Well it's time to get going on building my second tekno,with all the info you guys have given me I hope to resolve a lot of my issues I'm having with my current tekno. Thanks everyone,I will keep you posted and keep asking key questions whenever I can.
To the OP:
To the OP:
Hey guys I have a problem with my gen 2. I posted this same thing in the RX8 thread but figured id do it here too since a lot of you guys run similar set up. It's brand new. Hooked up to a HD4300 motor in my tekno sct 410. I'm using brand new Smc 5000mah batteries. I get about 5 min run time until the ESC will shut down and restart every 30 seconds. I'll have no power, only steering. Once the ESC resets the truck will run just fine again for about 30 seconds and it will cut power and restart again. I know this because one of the guys was standing by the corner of the track when it happens and he hears the ESC restarting. Any ideas why this is happening? I check my batteries right after this happens and they are around 3.8v per cell still.
17Likes
