Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 02-21-2014 | 09:27 AM
  #1831
Guch's Avatar
Hey alaphoid i realy LMAO at you on the movie Grown ups.
Guch is offline
Old 02-21-2014 | 11:14 AM
  #1832
Randy_Pike's Avatar
Team Tekin
The case will not fit properly.
The Rx8 Gen2 has 220 amps per phase vs Gen1 Rx8 at 210 per phase.
Randy_Pike is offline
Old 02-21-2014 | 06:49 PM
  #1833
JEFFs SC10's Avatar
I picked up a AE 8.2 e
running a 19tooth pinion/stock spur
I want a little more low end punch
Is 10 deg too much,
Motor was temping 129
esc was at 113
For some reason fan is not coming on, I have it set to always on; are these fans fragile?
JEFFs SC10 is offline
Old 02-22-2014 | 06:29 AM
  #1834
alaphoid's Avatar
Guess I need to see that movie to get that
alaphoid is offline
Old 02-24-2014 | 08:20 PM
  #1835
Guch's Avatar
There is this scene were all the wife's are setting by the pool and this dude, on the other side of the pool flexing his muscles, catches their eyes. This dude comes over to the ladies and mentions his is from saskatchatoon. It was just a stupid joke. I know your really not the guy in the movie. When I saw your location it reminded me of that scene. Sometimes I get easily distracted. My wife calls it the "squirrel syndrome". I could be talking about one thing and next thing you know I'm off on another subject. Sorta like a dog that is concentrating on one thing but as soon as he sees a squirrel he's gone. Oh yeh, this it the RX8 forum, see I did it again.
Guch is offline
Old 02-25-2014 | 01:45 AM
  #1836
I'm getting an RX8 Gen2 1400 combo for my JQ THE eCar. I'll be running it with a 3200 mAh 6s 25C Venom hardcase pack. I'll be geared quite low at 45/12 with an internal ratio of 3.307. What kind of run times and performance can I expect?
I race on a medium sized track, low/medium traction and I am very smooth on the throttle. I'll probably be running low minimum throttle and 70 current limiting.
Also, can I adjust the current limit and minimum throttle without a hotwire?
iamahuman is offline
Old 02-25-2014 | 06:58 AM
  #1837
alaphoid's Avatar
Actually running a 6S lipo I think your gearing will be just about right, that will put you at just under 40mph.
I also have the eCar and am going to be running it with a RX8 Gen2 1900kv combo on 4S and starting at a 16t pinion, which could be a touch overgeared, might back off to a 15 or even a 14. I think your probably looking at somewhere around 20 mins of runtime but that pack could be a little bit weak at 25C, although hard to say how accurate that spec is. I played it safe and went with a 4S 70C pack.
http://www.teamtekin.com/manuals/RX8...nual_22813.pdf
Looks like you can adjust the current limiter but not the minimum throttle without the hotwire.
alaphoid is offline
Old 02-25-2014 | 07:41 AM
  #1838
20 minutes sounds great.
I did the math at nominal voltage for a lipo and the top speed is 34mph which seems like a safe bet. A 6s setup won't draw a lot of current and current limiter at 70 would be quite safe, right?
I checked the manual moments after I posted and saw the available options.
It's great to see another jq user around here.
I'm excited to be getting the tekin. Hurry up, usps!
Old 02-25-2014 | 08:17 AM
  #1839
Integra's Avatar
Integra is offline
Old 02-25-2014 | 08:23 AM
  #1840
alaphoid's Avatar
What are you laughing at Moxley, Winnipeg gets its fair share of shots too
alaphoid is offline
Old 02-25-2014 | 08:25 AM
  #1841
Randy_Pike's Avatar
Team Tekin
Is 10 deg too much,
esc was at 113
Gear up a tooth or two.
The fan only comes on when the temps require it. To test the fan and fan control, unplug the esc from the receiver, power up the car. This will force the fan to run non stop.
Old 02-25-2014 | 08:32 AM
  #1842
wittyname's Avatar
Randy, I am looking at T8 motors for a x ray xt8 truggy I have. Right now I have a non sensored 1800 in it. I have a rx8 gen 2 for it , and now I am on the fence between the 2250 kv or the 2000kv t8. 4s only for this one . Is one a clear choice over the other ? Thanks in advance for your answer ...
wittyname is offline
Old 02-25-2014 | 08:56 AM
  #1843
Randy_Pike's Avatar
Team Tekin
Josh both are good but I've never found a track or time where I felt I needed more than the 2000kv. The 2250 is a beast and at times, way too much power. The 2000kv will wheel stand the truck at will assuming there's grip. Heck I could still rip a wheelie at the end of a 10 minute main last time I ran it.
Old 02-25-2014 | 09:56 AM
  #1844
Integra's Avatar
THAT'S it BACK to Winnipeg.
Integra is offline
Old 02-25-2014 | 01:25 PM
  #1845
Help!!!! I got brown out on my buggy guys. I am trying to call Tekin but I guess there workjng .
I am running savox 1267
Tekin rx8 gen2
Smc 7200 2s
Spektrum radio system
And a rtr 2800kv losi 4wd corr motor.
And it browns out at 5:00-6:00 minutes in on a heat race and mains.
S.TRIPP77 is offline
