Like Tree5Likes
SC10 4x4 Thread
Old 02-20-2014 | 04:35 PM
  #35956
Horskinator's Avatar
Well my SC10 4x4 FT kit came in and is assembled for the most part. All I have left is some wire shortening but all the running gear is in place and ready. I am hoping to get all the wiring and finish off the build by Saturday night. I am taking a break from it tonight as I did most of it the last 2 nights. I will have to do all the turnbuckle adjustments, bumpers, and paint the body. Very solid kit and relatively easy to build. I am hoping to get it on the track Sunday. I also need to get the used 2wd running which just needs a servo screw and I am putting in a new receiver to match the 4WD. Ill update with how it goes.
Horskinator is offline
Old 02-20-2014 | 05:01 PM
  #35957
Much smarter than what I did...That's for sure. I wanted to race a day and a half later so I built it through the night. By the time I finished everything it was 24hrs later and I had only 3 hours of sleep. Mind you that 3hrs helped a lot..hahah. Kit is sick and don't let other's you should have went with something different. Btw if you do have trouble with your belt falling off just tighten it more.
lee111m is offline
Old 02-21-2014 | 09:00 AM
  #35958
Cain's Avatar
looking forward to hearing how it goes.
Take video if you can.
Cain is offline
Old 02-21-2014 | 07:08 PM
  #35959
MantisWorx's Avatar
V3 CENTER DIF PRE-ORDER BEGINS NOW! THESE THINGS SELL OUT FAST SO DONT WAIT UNTIL THE LAST MINUTE. I CAN ONLY MAKE SO MANY AT A TIME AND IT IS FIRST COME FIRST SERVE!!
RCShox.com
MantisWorx is offline
Old 02-21-2014 | 10:12 PM
  #35960
I just drilled and installed my saddle holder. now I have to wait till may to use it
lee111m is offline
Old 02-25-2014 | 12:17 AM
  #35961
GraphiteChassis's Avatar
Does anyone know of some other 13mm springs? I modified the arms and shock towers to push the shocks out closer to the tires...
I have it close but need softer springs.
Currently Whites with 25/27 oil is still too stiff.
The mod is good, just need softer springs.
GraphiteChassis is offline
Old 02-25-2014 | 07:37 AM
  #35962
louielou's Avatar
Default sc10
Does anyone know where I can get a stronger spur gear, possibly metal.
louielou is offline
Old 02-25-2014 | 07:48 AM
  #35963
What pitch are you using currently, the kit comes with 48p and a 32p. You can look at getting a mod spur gear(1/8th scale). But you shouldn't need a metal one. Make sure your gear mesh is set properly.
lee111m is offline
Old 02-25-2014 | 12:49 PM
  #35964
Cain's Avatar
good question on what pitch. the 48p one is definitely not robust enough for high torque motor usage in my opinion if your gear mesh is at all off.
Cain is offline
Old 02-25-2014 | 05:47 PM
  #35965
Nothing horribly constructive to add here.. but I'm finally getting the bug to race 4x4 short course again so I figured I'd put my FT together (been sitting - new in box for about a year now) and I stumble upon this gem...
Looks like I got an unfinished tensioner base
Vermin is offline
Old 02-25-2014 | 06:19 PM
  #35966
Is that right out of bag?
lee111m is offline
Old 02-25-2014 | 06:43 PM
  #35967
Cain's Avatar
lol.
Cain is offline
Old 02-25-2014 | 08:41 PM
  #35968
louielou's Avatar
Default spur
I'm using 32p. Just wondering if anyone had anything a little stronger.
louielou is offline
Old 02-25-2014 | 09:12 PM
  #35969
MantisWorx's Avatar
Mod1 centerdifs are on pre-order right now!!
Old 02-26-2014 | 04:46 AM
  #35970
Yeah - just my luck. I have spares from my other SC10 though.. so no huge deal, was just sort of shocked that would make it thorugh quality control
Vermin is offline
