NOVAROSSI Engine thread....
#6361
#6362
If I remember correctly the beat 4 is similar if not the same as a plus 4 btt, its not really a truggy engine. I would say run the 53 pipe and 41021 header if you have your heart set on running the beat 4 in truggy.
#6365
Having ran that engine in my truggy, i will tell you from experience that if you have short run ups to jumps you will definitely miss the 9901, for the most part the 9901 is better than the 2096 for that engine in truck, or you can try the 9853 which is awesome.
#6366
I have an old Novarossi 2001BF .21 engine. Runs great. But I am looking to or wanting to convert it from a standard plug to a Turbo plug.
Will a P5 or P5xl turbo button work on this motor ?
If so what else will I need to do to make sure I am not damaging the motor?
#6367
This is our track. Not much of a high speed track, recorded fastest lap time is 37 sec. We use P5 and Plus 4 with 9901 pipe.
Will a KeepOff 4 port suffice or should we consider a 7 port? I know the 7 port is more high tech. I also race occassionally at PRC track, Pattaya-Thailand.
My track buddies have been pushing me towards OS, but hearing mixed reviews. Hope I will not regret the Nova purchase.
#6368
Drake races at both tracks all the time and is using a keep off 4 with the new carb. He says the new carb makes the low end more crisp and gives a little bit more all around torque to the engine, but no significant increase or decrease in runtime.
#6370
The Clio looks interesting!
Looks like they are using the +4C crank and team piston like the BTTA, new head and button, and the new carb.
Can anyone chime in with a price? Do you think they will still be valued somewhere around 200-225? I hope so!
#6371
You will see it has 15009T crank, so that's not what's in the +4C.. team piston, yes..
So basicly this is a Maxy's cinco, but in Novarossi branding, but with the new carb.
I think it should be a nice little engine, and I'd be wanting one if the price is right
#6372
No, if you look at this: http://www.novarossi.it/2012/images/...va/CLIO-P5.pdf
#6374
The CLEO will have a street price of $300-325. If you want a $200-225 engine the P5XLT will continue to be available in the USA.
352Likes
