Speed Passion Thread
#4442
#4443
Brand new Reventon 1.1 here straight out of the box and can't programme. downloaded the software and drivers. Connected the LCD box and all it says in Connecting to PC for hours and the software says in pink - connect to esc. None of that works even if i connect esc the esc lights up orange and thats about it. So my first track session was MOD1 I guess default with no drag brake.
Any thoughts>?
Any thoughts>?
#4445
i did some searching and seems the conversation left off about this time last year. . but, im curious about running a SP esc either revention or gt for 4wd short course with a 4000kv 4 pole. i remember some discusion about no timing etc, which thats the way i beleive most other esc have to run those motors as well. any update im not seeing in the search?
#4446
Alan,
Many of our drivers have started using the newest line of Blaze motors that were made to run with the Reventon line of ESCs. Do you have a question in regards to if anything has been updated or looking for example ESC settings running 4x4SC?
4600KV pictured here.
#4447
Hello there
I have a problem with the controller Reventon Pro 1.1 Brushless ESC - Metal Black Silver
The cutoff is set to 3 V after the cutoff vehicle shuttle stops the car at 3.8 V
Is there a solution to this problem that happened with my batteries Turnigy nano-tech A-SPEC 5600mah 2S 65 ~ 130C Hardcase Lipo Saddle Pack and the same thing happened to my friend with the same controller
It is important to note two new controllers
#4448
so a revention pro will run the blaze 4600? but not somthing like the hobby wing 4000? or tekin pro4 motors? ill look into the blaze stuff, because id really like the have a revention pro again , but in a 4wd sc . is the blaze 4600 a 4 pole motor?
#4449
Hi!
One question, will the Reventon R work OK with the Speed Passion Competition V3.0 5.5t? Would this be a crazy setup for a 2wd buggy?? It is just to play around... Speed runs and some jumpings...
How about the gearing for that motor? What FDR should I use?
Thanks!!!
Thanks!!!
#4450
Hi!
Thanks!!!
Thanks!!!
Personally, I wouldn't go below 7.5 with the R.. On ebay you can get a Pro for like 89 bucks with free shipping so if you really want a 5.5 that would be the safest option.
#4451
Edit: couldn't find a pro for that money... I can get the R on a combo with the motor for 100 and is offered with the 5.5t too... So 7.5t is OK?
#4452
I just looked and it seems they are all more now! sorry about that. But 7.5 should be fine. I know they say you can go down to 5.5 on the R... I think when you get that close to the limit you are pushing it.. I run 8.5's on my R's and have yet to have a problem. So I'm sure 7.5 would be fine
#4453
#4455
4Likes
