Team Associated B4.2 Thread >
Like Tree4Likes
Old 12-24-2013 | 06:31 PM
  #12016
Originally Posted by JeepnMike
Now that I have my shorty packs, do you guys mind to please tell me what you are using to keep the battery seated and forward? I am assuming it is similar to the foam inserts that come with the kit, there is just a couple of inches I need to fill now and I am not sure if a wad of pads is a good solution. I wasn't planning on using an ESC shelf, I still might not, undecided (if that makes a difference). I did an image search to save myself from asking lame questions, I just didn't see anything conclusive.
Thanks again for all of the great advice you guys have given!
Merry Xmas!
Mike
I use an ESC shelf and mount my receiver below the ESC. I drilled and countersunk 2 holes in the chassis and mounted a toe block as the rear stop for the shorty Lipo. I have always liked running my batteries all the way forward with shorty packs.
fivepointnine is offline
Old 12-24-2013 | 06:34 PM
  #12017
the incubus's Avatar
Thanks for the response! I just realized there was an actual market for these, I had no idea. I just realized Avid sells them, etc.
Might as well ask, are ESC shelfs trendy or awesome? I am going to get this car done and awesome just in time for it to be outmoded. LOL
Thanks!
I just picked up 2 Reventon Pros so I'm going to change my layout with the ESC on the right side instead of the left to offset the weight of the motor. I had the ESC up top and it was OK but my car has more than enough turn radius and I prefer to keep all weight as low to the ground as possible. The biggest change with the shelf is increased roll which is said to improve turning a bit, but if you want or feel you need more roll you can simply slap a few grams on the shock tower or like one guy at my track does, you can place it on the underside of the body and achieve the same thing. The heavier the weight, the greater the roll.
the incubus is offline
Old 12-24-2013 | 07:09 PM
  #12018
JeepnMike's Avatar
Thanks for the reply Zak. Is there any notable difference between the AE and the Avid shelf? I can read what is on Amain, I was just looking for unbiased advice.
Thanks again!
JeepnMike is offline
Old 12-24-2013 | 07:11 PM
  #12019
Avid Shelf>Every other Shelf.
It features adjustability that no other shelf has.
Old 12-24-2013 | 07:22 PM
  #12020
JeepnMike's Avatar
Thanks man, I will go that route. Thanks for all of the helpful replies!
Y'all have a Merry Xmas!
Old 12-24-2013 | 07:27 PM
  #12021
2-shot's Avatar
I have an Avid esc shelf that I ran on my buggy for 4 races. It didn't really work for the type of track I race on, so I took it off. Out of the few shelves made, the Avid shelf is the best one in my opinion.
2-shot is offline
Old 12-24-2013 | 07:58 PM
  #12022
just watch the clearance of your ESC, with the shelf. My Novak GTB2 non-low profile rubs against the body (JC Finnisher) My BHR 80A did not
Old 12-24-2013 | 08:19 PM
  #12023
2-shot's Avatar
The HW V2 that I was running did not rub against the body. I was not running the fan, and I was not using the stand-offs that come with the Avid shelf.
2-shot is offline
Old 12-24-2013 | 09:08 PM
  #12024
JeepnMike's Avatar
Thanks for the extra info. I will be running a Tekin Gen 2 ESC so it should be good. I went ahead and ordered the Avid shelf with the Avid shorty spacer pads, it looked like it would work well with shorty and regular packs which is what I wanted.
One of these days I will see you at TRCR.. I usually just go there and spend all day practicing (great way to spend a day off of work!). Thanks again for all of your advice!
Old 12-25-2013 | 12:32 AM
  #12025
skrichter's Avatar
B5
http://www.teamassociated.com/AREA51/B5_B5M/
skrichter is offline
Old 12-25-2013 | 12:37 AM
  #12026
Tradin Paint's Avatar
Just in time for everyone that got 4.2 or Centro kits for Christmas to be really pissed off
Tradin Paint is offline
Old 12-25-2013 | 01:53 AM
  #12027
Cridd's Avatar
Going to run centro and get B5 and dump B4.2 is 2 or 3 months when they are available.
Cridd is offline
Old 12-25-2013 | 09:45 AM
  #12028
how many people are really going to buy both the B5 and the B5M? That seems like a lot to have rear and mid motor....
scottie_smith is offline
Old 12-25-2013 | 09:59 AM
  #12029
I have a question for those of you running the esc shelf. Are any of you running the receiver in the battery tray? Also, are you just securing the receiver with servo tape and mounting the foam block in front of it? Thanks.
AERob is offline
Old 12-25-2013 | 10:14 AM
  #12030
RCBuddha's Avatar
I'm going to buy both.
RCBuddha is online now
