Team Associated B4.2 Thread
I used a piece of scrap lexan flashing from a body. It's molded at 90 degrees, taped it to the bottom of the chassis with 3m double sided tape, lip toward the front. Then I mounted my esc on top, then inserted a small foam between the esc and the lip on the lexan. Then a normal foam, with the shorty battery all the way forward. Not the cleanest install, but has worked so far. Cheaper than a shelf too.
Hey all, I hope everyone had a great holiday! Question... 8mm is not that much, is it really worth getting the +8 chassis? I've been customizing by B4.1 and have an extra chassis that is the FT Carbon, yet I've been thinking about the +8.
If you race on a tight track, the +8 is not needed. It will give you more stability on a higher speed open track though. It will also help give more stability if you race on low traction surfaces as well.
As long as your front tires aren't rolling over on themselves (combo of soft tires and foams), then you'll likely gain a bit more mid-corner steering.
Increasing ballstud height will increase roll in the corner. This can increase or decrease steering based on the rest of your setup.
I was running ss ribs. I tried adding weight to the tri in the front, further forward under the shock tower. Then I tried camber from zero to -3. Then moved the ball studs in on the tower and out on the hubs. Finnaly ended up having too much steering when I put on SS Suburbs. Here is what I ended up with.
Inner Ball studs on inner holes 1silver and one blue spacer, outers on the outer hole with 30 degree caster blocks.
-1 degree camber
3 chuncks of lead under the front tower (forward one is trimmed to fit perfectly) but none in the tri's.
M3 Suburbs with 1/2 open cell foams.
bottom of the front arms level with full pack.
I don't run any of the carbon stuff. I tried the molded foams but didn't like the high speed steering they had and never used a shorty pack.
Hope this helps.
You should! I didn't think it would make a huge difference either. I was completely wrong. Removing the rear ball stud washers combined with decreasing the shock oil (40>35), made the rear end of the car FAR more predictable. Still a little bouncy on some of the sections coming out of the corners, but the track has been neglected since the last rain (last saturday).
I had the same issue but....
-1 degree camber
Hope this helps.
-1 degree camber
Hope this helps.
4Likes
