Tekno RC EB48 Thread >
Like Tree2Likes
Old 12-02-2013 | 12:33 PM
  #10081
Mizchief's Avatar
I'm not knocking your style, but IMO running two stick packs is a pain and unless it's a setup like the durango's where you run the packs on separate parts of the chassis, I don't think it's worth it. (coming from saddle pack experience with the AE 4x4 SCT)
You pretty much have to charge them and use them as if they were one pack anyway, might as well just get them pre-wired with a deans. Now if you already have the packs and want to reuse then go for it.
I've been running the SMC 6500 in my RC8.2, I hope it balances well in the EB48
Mizchief is offline
Old 12-02-2013 | 12:49 PM
  #10082
Numburn's Avatar
Well, I ran electric buggy for almost 2 years and went through many 4s packs. They just don't seem to be able to handle the abuse. It isn't from cells dying so much as connections breaking within the packs. 2s packs are a lot sturdier.
Is there any reason to charge them as a 4s pack instead of separately?
I'm not completely sold on the 2s route and could definitely be convinced to go back to 4s. I also need a new charger and that decision dictates which charger I get. If I go with 2s packs then I'll get a 4 port charger. If I get 4s packs then I'll get a more powerful 2 port charger.
Numburn is offline
Old 12-02-2013 | 12:52 PM
  #10083
cpt_RedBeard's Avatar
Originally Posted by Numburn
Which packs are you running? Do any others have the pass through? I'll have to look for a male/male bullet. Sounds like a real good setup.
Originally Posted by Cain
right now I am using 7200mah IP lipos from promatch as that is what I use for my Tekno SCT410. I am however looking to buy some dedicated 4S packs in the future.
Promatch also sells 6000mah packs with the same pass thru as well.
Promatch also sells male to male bullets as well.
I have been toying with the idea of taking a pair of shortys and drilling them out so I can pin them together to make a 4s shorty pack. Not only would they be lighter, they would also allow for me to play with weight placement.
cpt_RedBeard is offline
Old 12-02-2013 | 12:55 PM
  #10084
smc has a new 4s shorty
rkhess is offline
Old 12-02-2013 | 01:15 PM
  #10085
Mizchief's Avatar
Actually now that I think about it I may have been wrong. I know when your pack is wired in parallel your supposed charge them as if they were one pack and should not let one get worn out faster than the other, but not sure if it's as big of a deal when wired in series assuming you keep them balanced to the same voltage.
Mizchief is offline
Old 12-02-2013 | 02:30 PM
  #10086
Cain's Avatar
yeah, that new SMC 4S Shorty has me toying with the idea of a light buggy
Cain is offline
Old 12-02-2013 | 02:59 PM
  #10087
Mizchief's Avatar
Yea those might be just right for this buggy. I ran a Protek 4600 in my RC8.2 for a while and got 10min mains no problem. Only reason I went so big last time was that it was the smallest race formula they offered in 4s at the time.
Mizchief is offline
Old 12-02-2013 | 03:13 PM
  #10088
ToddMcM's Avatar
Well, picked up a .2 kit yesterday afternoon. Started building, few things I love, few things I don't.
Without reading through 673 pages, anything to look out for as I continue my build.
I'm building it with the Barry Baker OCRC setup (that's the only track I run at these days).
So stoked on building a kit, it's been too long!
ToddMcM is offline
Old 12-02-2013 | 05:27 PM
  #10089
BLbound's Avatar
That's basically what I've been running, Barrys set ups work very well for me. I built mine with no issues what so ever. Good luck!
BLbound is offline
Old 12-02-2013 | 05:43 PM
  #10090
BLbound's Avatar
Hi Tekno, it would be more than awesome if Chad Paneks setup could be posted either here or on your site? Thanks for your help!
BLbound is offline
Old 12-02-2013 | 11:13 PM
  #10091
You have any idea how close you just came to costing me $190!!!
Old 12-03-2013 | 01:45 AM
  #10092
if you want a light buggy wouldt you do the super light conversion sct to buggy
RavensNightFury is offline
Old 12-03-2013 | 03:47 AM
  #10093
Just a bit of advice to people thinking of drilling through their battery terminals to run a double male adaptor. If the terminal is blind I.e. Has a bottom to it, when you drill it the drill bit will snag up twist the terminal and break the wire soldered to it. To repair this you will have to cut open the case and re solder it back on if you want the battery to work again. I have found some actually have a through terminal (no bottom) so when you drill it you are only passing through the case on the bottom side, just check before you try it.
goldy is offline
Old 12-03-2013 | 11:05 AM
  #10094
boudin4evr's Avatar
speaking of lipos
I have 3 4s lipos with 2 race days on them
i always store after racing
i went to charge them this past weekend and they only show 3 cells!!!!
does that mean that the little sensor side wires have com un-soldered inside the case?
im deathly afraid of opening up to look! anybody have suggestions?
boudin4evr is offline
Old 12-04-2013 | 12:58 AM
  #10095
Do I HAVE to use the shims when assembling the eb48.2 diff into the gearbox? I tried for over 20min to fit both shims but there was just no room. One and sometimes both would be all bent out of shape when I place the other half of the gearbox together. No strange noise and drive pinion / diff action feels smooth with one shim on just now. At this point I am telling myself that with use the gearbox will wear and I will need the extra shim. (I repeated so many times last night it might even be true now )
Also I don't understand why the bump stop washers go where they are shown in the instruction. Why are they between the bolt head and the ball of the ball joint rather than between the ball and the steering rack? Or would that then be affecting ackermann rather than bump stop? I'm confused. TIA for anyone who can school me on this.
one-nil is offline
