SC10 4x4 Thread
Belt stretch is rare but possible. More likely front to rear chassis flex allowing for slack in the belt. Check your chassis brace and all the screws that hold the front and rear sections on. If you don't have a chassis brace, get one.
Did this just start happening or has it been from the get go? If it just started how long have you been running, what condition is the pulley and belt and what are your tensioners set at?
for the belt falling off the pulley issue, from what I recall one cause was if you assembled the pulley wrong. Look at the manual again and confirm you have it assembled correctly as I believe you can assemble it wrong and the belt can eventually slide off.
Yes, it does matter if you are running without the front cover. I had the same problem when I tried to run without the cover, and found that the plastic pulley mount can flex too much without the cover on. One of the mods on this thread shows a front pulley mount fashioned out of carbon fiber.
Reedy just announced a Mach 2 4 pole in 4300 & 4800kv for SC 4x4s!
http://teamassociated.com/news/lates...rushless_Motor
tower has them listed, here is one:
http://www3.towerhobbies.com/cgi-bin...?&I=LXEAEP&P=7
initial price of $173.99 . I am assuming it will go down to about the same price as a Tekin 4 pole, maybe $10 more but not sure.
I was wondering about that actually, I have seen a lot of people rave about the HW motor, so I just assumed it was ROAR legal, so its handy to know it isn't.
I recently purchased a new sc10 4x4 limited monster energy addition. First off i love this truck and its my first SC truck and first associated as well. When running on my friends back yard track it ran great but my only problem was horrible traction. If I gave just a touch too much throttle it would do donuts in the turns. Any suggestions or help in fixing my traction problem? Thanks in advance
5Likes
