Like Tree5Likes
SC10 4x4 Thread
Old 11-15-2013 | 07:00 AM
  #35566
turbonutt's Avatar
I noticed on the proline site that it shows the same rims for the Losi and the Associated, does the SC10 4x4 now use the 0 offsets? I'm thinking on switching over from Losi and this would be a bonus as I have quite a few sets of tires that are barely run.
turbonutt is offline
Old 11-15-2013 | 07:08 AM
  #35567
Cain's Avatar
Tech Legend
good question.
I haven't heard of any changes to to the suspension that would get you to what the +3mm wheels give with zero offset wheels.
I am thinking its basically the same type of wheel you get as far as offset goes (or close) that it comes with out of the box as the sc10 4x4 wheels out of the box are zero offset, or at least, AE zero offset. Losi's zero offset may be slightly less offset, if that makes sense.
Cain is offline
Old 11-16-2013 | 02:00 PM
  #35568
joykiller44's Avatar
anyone use the under drive on this truck is it worth buying ?
joykiller44 is offline
Old 11-16-2013 | 02:31 PM
  #35569
GraphiteChassis's Avatar
Never and never heard of anyone doing. It would make rear spin faster than front.
Front Overdrive is good for sweepers, fast flowing tracks.
They should come with the truck though.
GraphiteChassis is offline
Old 11-16-2013 | 02:37 PM
  #35570
Thats what i ment I got the truck used $50 for FT truck
Old 11-16-2013 | 04:50 PM
  #35571
I finaly got my c diff from rcshox today.
The left over shavings wernt so bad. I did take a knife and cut a few of the shavings off.
The spacers i got were black and they did not have an ''alfalfa'' nub on them.
the rings and the diff rings did not seam out of round, i spun the spacers around in the diff rings and could not find any gaps.
(the diff ring was not on center when i took the pic)
I can't wait to test it out tomorrow
slashmaxx242 is offline
Old 11-17-2013 | 01:56 PM
  #35572
Cain's Avatar
Tech Legend
cool let us know how it goes. Did you find the online assembly instructions?
Cain is offline
Old 11-17-2013 | 02:23 PM
  #35573
Yes I found the online assembly instructions.
It diff felt great. I have a clay track that is slightly loamy, M3 Tazers in the rear and M2 Blockades in the front, should i be running more or less pins or is four a good number?
Old 11-17-2013 | 04:14 PM
  #35574
Cain's Avatar
Tech Legend
I'd recommend starting with 4 and see how you like it. If you feel traction however is high, go with 6 to start then.
I personally liked 4 outdoors, loose conditions, and indoors high traction carpet I liked 8 pins.
Cain is offline
Old 11-17-2013 | 04:16 PM
  #35575
Anybody running the reventon pro with a 550 can in this truck?
boobie817 is offline
Old 11-17-2013 | 08:51 PM
  #35576
Default Warehouse 3 Peoria setup suggestions
I'm planning on heading down to the track sometime in the next several weeks and am hoping someone will share a good base setup. It looks like they only run open in the 4x4 class so will be running either the Pro4 4600 or RevTech 3800. I hear Ions are the go to tire but am clueless beyond that.
Thanks in advance for any help!
AzFittin is offline
Old 11-18-2013 | 06:52 PM
  #35577
TommyJoe's Avatar
4600kv is pretty high for an indoor track. I'm running the Tenshock 4400kv geared low*(62/12) on a 1/8 scale outdoor track. A motor in the 3800-4200 range would maximize your gearing options. And clay compound Ions work well on high-bite clay. Good luck.
TommyJoe is offline
Old 11-19-2013 | 04:34 PM
  #35578
Newdieselguy's Avatar
Couple of servo ?'s
What's the recommend min. speed and torque?
Had the AE 1015 thinking about the Savox SC-1256TG, will I feel the difference in speed, will it possibly be a down grade?
Newdieselguy is offline
Old 11-19-2013 | 05:00 PM
  #35579
Cain's Avatar
Tech Legend
I would suggest close to 200oz torque, and .15 or faster transit time.
I used JR9100S and really enjoyed it on the vehicle from what I recall.
Cain is offline
Old 11-19-2013 | 06:15 PM
  #35580
I cant keep belt on the front pully. does it mater if I am running the cover over the pully. Maybe my belt is streched or tension pullys are worn out.
sgtlt is offline
