Like Tree5Likes
SC10 4x4 Thread
Old 11-01-2013 | 08:19 PM
  #35536
Cain's Avatar
Originally Posted by Sofa King
See attached setup sheet. I was #6... truck not holding me back, lol, I'm holding it back.
I know #2 was Losi and think #1 was also, but not sure. #5 was other SC10 4X4.
Not seeing a setup sheet?
Cain is offline
Old 11-02-2013 | 12:02 AM
  #35537
Try again...
Sofa King is online now
Old 11-02-2013 | 02:29 AM
  #35538
joykiller44's Avatar
Try again...
i can't read it
joykiller44 is offline
Old 11-02-2013 | 06:29 AM
  #35539
Cain's Avatar
got it!
Must be some serious traction since you are running all 10 pins?
For your pistons, are they modified? reason I ask is the oil weight is higher than what I have seen in general with the RC Shox pistons? Curious what you noticed on your conditions.
Looking forward to more info, with indoor season going for a lot of people various setup advice from you and others running in these conditions will be great info.
If people are still having issues reading his setup sheet, I can copy down the info and post it in a reply for everyone.
Cain is offline
Old 11-02-2013 | 09:06 AM
  #35540
Wild Cherry's Avatar
Sc Saturday's @ TRCR & PINK will be in da house ....
Come get some .....
Set-up views great King ...
Selling hard to get some to come up . P-town comes up as a objection, thinking after the shoot out a gang will come to play however .
Traction Conditions at N/w indoor facility's
Trcr
High Traction , smooth , no dust ....
sweeper's between each heat
BRCR ( B-Town)
med to high traction , slightly dusty, smooth
sweepers used between each heat
4 Season's ( Lacey)
med traction, smooth
sweepers used between heats
Mikes ( Bell Town )
med traction , smooth , big jumps , dusty
sweepers use between each round
Top Gear ( P-Town)
smaller track , high traction , smooth, sweepers used between heats
Wild Cherry is offline
Old 11-02-2013 | 01:08 PM
  #35541
got it!
Yeah, traction is good... and more pins helps when the run up to the jumps are short.
RCShox pistons are unmodified... just trying out heavier oils as some have. It is ok on smooth track, but certainly too heavy for a rough track. Going to try emulsion with stock pistons next.
Old 11-02-2013 | 01:16 PM
  #35542
Cain's Avatar
cool.
For carpet I was at 30W front, 25W with rc shox pistons.
Cain is offline
Old 11-03-2013 | 08:35 AM
  #35543
Default Computer Vision
Just a peep of
cutting edge tech developing PINK set-ups ....
Oyeah ....
Attached Thumbnails SC10 4x4 Thread-1455170_10201948753307631_654583508_n.jpg
Old 11-05-2013 | 08:48 PM
  #35544
What options is there for alloy rear uprights ?
dan200487 is offline
Old 11-05-2013 | 09:30 PM
  #35545
Do you mean rear alloy axle hub ?
Old 11-05-2013 | 10:29 PM
  #35546
GraphiteChassis's Avatar
Check out integy. They're alloy and graphite. http://www.integy.com/st_main.html?p_catid=349
Wow...
GraphiteChassis is offline
Old 11-09-2013 | 09:02 AM
  #35547
Aaah yeah !!!
Racing the PINK SC10 4x4 today ..
Hoping some of the faster rides show , will even
practice a little for a change ...
Onoooo !!! Still not one aftermarket part on my ride ....
No deal breaker though .....
Old 11-09-2013 | 09:26 AM
  #35548
Cain's Avatar
what! you mean that Hot Racing rear hub carrier from Toad's RC that you said was an improvement on your SC10 4x4 over the stock hub carrier you found wasn't but didn't say that yet?
Oh Man!
Cain is offline
Old 11-11-2013 | 04:42 PM
  #35549
wild cherry can I pm you for some setup advice ?
sgtlt is offline
Old 11-11-2013 | 06:29 PM
  #35550
sgtlt
Welcome to the thread ..
Sorry , I don't use Pm ..
Always here to share what I know.
Also this way get to learn from you
and others that own the Sc10 4x4...
