Team Associated B4.2 Thread >
Like Tree4Likes
Old 10-20-2013 | 04:18 PM
  #10621
Gene158's Avatar
After getting some more trigger time in with my buggy, I'm still struggling with setup. By adding some anti-squat and making a couple other changes, I managed to get a little more traction in the rear. However, the car is still really unpredictable and hard to drive. My friend drove it and had the same complaints. I'd almost go so far as to say the car is stiff and bouncy but I think unpredictable describes it better. I'm running ae 32.5wt oil in the rear with stock piston and white spring; same setup in the front except I'm using the black spring. I'm gonna try going down to 30wt in the rear. Any other changes I should make?
Gene158 is offline
Old 10-20-2013 | 04:21 PM
  #10622
Grasschopper's Avatar
Originally Posted by Jstall7543
Hey guys a guy at the track accidently cracked my B4.2 front shock tower, I'm wondering should I modify a b4 carbon tower to clear the 12mm shocks or is the b4.2 geometry different?
Is the same but it has the upper spacers built into the area where the shocks mount. H top of the B4.2 tower is about .070" thicker than the previous part...all added to the back side of the tower.
Grasschopper is offline
Old 10-20-2013 | 04:22 PM
  #10623
Wildcat1971's Avatar
Tech Prophet
you can use spacers and grind the carbon tower
Wildcat1971 is offline
Old 10-20-2013 | 04:23 PM
  #10624
Tech Prophet
32.5 with 1.6 pistons? seems a bit stiff. are you on carpet?
Old 10-20-2013 | 04:24 PM
  #10625
silveraider14's Avatar
deffintly go to lighter weight shock oil in the rear.
I was at 27.5 wt with stock pistions
silveraider14 is offline
Old 10-20-2013 | 04:29 PM
  #10626
BLKXJ96's Avatar
Try:
Front: 1.6 pistons with green springs and 30wt
Rear: 1.6 pistons with white springs and 27.5 wt
Are you running any weight in the car? this will help settle it down also.
BLKXJ96 is offline
Old 10-20-2013 | 04:58 PM
  #10627
5th wheel's Avatar
I run 69spur and 35pinion in 17. 5 stock. But run on a large track. High bit
5th wheel is offline
Old 10-20-2013 | 05:36 PM
  #10628
mashimarowu's Avatar
Any suggestions for me in shocks since I'm running a full stick pack, 17.5T, medium grip indoor track?
Tend to chassis slap a lot and going off jumps just end up crashing on the other end, seems like there is not enough launch from my shocks.
mashimarowu is offline
Old 10-20-2013 | 05:37 PM
  #10629
Jstall7543's Avatar
Cool thanks!
Jstall7543 is offline
Old 10-20-2013 | 06:26 PM
  #10630
Gene158's Avatar
Thanks for the tips. I'll try 27.5. Jeff, I have the rear ballast weight and that's it. I'm also running a full size battery with the thick pad up front.
Gene158 is offline
Old 10-20-2013 | 06:43 PM
  #10631
Will this work on the B4.2 without other parts and do you recommend this upgrade? My stock slipper is about done.
goin2drt is offline
Old 10-20-2013 | 06:44 PM
  #10632
Tech Prophet
will what work
Old 10-20-2013 | 06:46 PM
  #10633
Tech Prophet
Originally Posted by slashracer111
I want to try a the C4.1 thingy. Just to be different.
I bet it would be dialed on the 10'x10' indoor track I run on in the winter.
my office is bigger than that, lol
Old 10-20-2013 | 06:47 PM
  #10634
BLKXJ96's Avatar
No problem,
there really is no correct answer for set up. With us east coat guys you need to take into account the temperature...most race nights it's 50* or less in the building I race at. The 30 Front, 27.5 Rear is what most guys run, some will even run 27.5 front and 25 rear. it all depends.
BLKXJ96 is offline
Old 10-20-2013 | 06:52 PM
  #10635
Oops. Long day.
http://www.amainhobbies.com/product_...Clutch-81T-84T
goin2drt is offline
