Tekno SCT410 Thread
I have a question for you guys. Where are you guys mounting your ESC's on/off switch at on your truck? I am running the side air guards so I have mine on the guard but I am looking around and don't know where else I can put it if I take off the guards. So right now that is preventing me from taking the guards off even just to see the difference in feel without them. I run the RX8g2
That looks like the place to put it. I always worry about it coming free and getting tangled in the driveline. But just have to make sure and use something good to hold it like shoe goo.
So if I eliminate my switch and solder the wires and such as soon as I connect the battery the power kicks on and then the battery connection basically becomes the on/off switch?
the hobbywing switch has been great so far. it has a replaceable rubber cover over it to keep the dirt out. If yours ever fails you could replace it with one of those.
yup. i like having an on/off switch but eventually my tekin switches started acting up and it was easier to just remove them.
Any one run a rx8 and tenshock sc411 combo in there truck? I was curious about gearing. I'm running a 15t pinion and it feels like way to much power!! I have turned my TX down to 40% and it's helped some. But I was hoping to hear from someone else who runs this combo for some input. I'm going to try a 16 tomorrow and see if that tames the punch some.
I drill a hole in the mudguard and screw the switch to it. If you look at the right side of the vehicle at the mudguard where the side bumper attach between the esc and end of motor there is spot that bumps up and it actually has 2 ribs on it that a tekin switch fits between perfectly. If u look at FQ6 picture u can see the bump up directly to the left of his esc. Just dremel a hole and use a screw and bolt.
I run that combo, I have the 4600kv and a RX8 gen1. I've tried both a 15 and 16t, and have been using the 16t with good success outdoors. It doesn't feel overpowered like you're describing, but it's pretty quick. I haven't changed the current limiter from stock and I'm running at about 115 after a 5 min qual.
17Likes
