1/12 forum
Been away for awhile. ..
Anyone ever use these 1s saddles?
http://www.speedzoneusa.com/estore/i...6a5cf235a83cf4
http://www.redrc.net/2010/01/speedzo...e-saddle-pack/
Was debating firing up my old CRC T-Force using these packs.
E
I am new to 12th scale. About to buy my first kit to put together. I have read way back to January on this thread and found some info. What im looking for it what it the 1s speedo of choice right now for 12th scale cars? I have to buy a new one and want to make sure its going to fit and do what it should.
SP GT2.1EX is my favorite.
No need for extras like a voltage regulator to clutter up the build.
http://www.speedpassion.net/us/catagory.asp?c=esc&sc=16
It may be worthwhile to have a look at the link in my sig
Lot of info there, including ESC choices
The Hobbywing v3.1 1s is great, the cap and switch are built into the case. ORCA, Viper and Team Orion also make great 1s speed controls that don't require any booster or receiver pack. Hobbywing also has their original 1s ESC for about $100 or less right now.
Anyone by any chance have run a Duo 2 13.5 blinky and have a good setup for motor timing and rollout they found to be pretty fast and stay somewhat cool temperature wise? Using a Hobbywing V3.1 1S Speedo for this.
Thanks,
Ivan
Thanks,
Ivan
These questions are mainly to the 1/12 drivers who race outdoors on asphalt;
What tyre compounds have you found best to use?
What additives work on asphalt, and which don't?
Paragon is a no-no, as are any other additives with 'wintergreen'
Skiddins
Skiddins
Running soft side springs will help with traction. If the surface is very slick, you can leave them out altogether.
Non-detergent 30W motor oil works reasonably well for tire glop, and is very cheap!
I'd try Pink rears and Purple front to start. Coppertone or other brand 30 - 50 SPF sunscreen works pretty well for tyre goop.
2991Likes
