Tekno RC EB48 Thread >
Like Tree2Likes
Old 08-30-2013 | 10:12 AM
  #8926
As I said in my previous post, I had to mod the spur gear, and whenever I use a plastic spur, I will use black sealant on one side of the paper gasket so it will seal right.
some guy is offline
Old 08-30-2013 | 07:47 PM
  #8927
Graham11's Avatar
Originally Posted by ChrisAttebery
I just received the SS front skid plates for the EB48 this afternoon. They came out great. They are available on my web site now.
Chris
Can you give more info on the modification? Is it a specific size tool to create the countersink? I've never done some thing like that in all my hobbying days.
Graham11 is offline
Old 08-30-2013 | 08:09 PM
  #8928
boudin4evr's Avatar
Chris
Very nice!
How much?
boudin4evr is offline
Old 08-30-2013 | 08:12 PM
  #8929
ChrisAttebery's Avatar
The front screw holes just need to be chamfered slightly. You can use a standard hand drill with a generic hardware store countersink. You don't need to remove that much material, just enough that the screw can tighten the plate down completely.
ChrisAttebery is offline
Old 08-31-2013 | 09:48 AM
  #8930
Graham11's Avatar
$24
Is there a combo price if you buy front and back and tools.
Graham11 is offline
Old 08-31-2013 | 11:53 AM
  #8931
Motorman007's Avatar
Are you asking if the 8x1.3 Tekno pistons come a tree like that picture you have? If so, no they are not attached to a parts tree, they come in a bag and are white.
I did not get any white pistons I got the Piston on the tree.
Do they come in the eb48.2 kit?
also, 2 of my shocks the piston are not smooth.
and I bought the opt. 8.1.3 tekno piston and two of them are not smooth
did i get some bad pistons?
I may have to sand two of the pistons down the opt ones that is...
Motorman007 is offline
Old 08-31-2013 | 12:05 PM
  #8932
Graham11's Avatar
Haha I'm so confused... I think I thought you were asking if the optional 8x1.3 pistons come on a parts tree, which no they don't. .2 comes with black pistons on a tree I think they're 10x1.2.
When u cut off parts tree yes u may need to sand nub but idk why whites 8x1.3 would not be smooth?
Graham11 is offline
Old 08-31-2013 | 12:29 PM
  #8933
I know..
the white piston two of them.
I will run them and see if they loosing up
Old 08-31-2013 | 02:03 PM
  #8934
What servo horn are you guys using with the hi tech 7955t servo?
somedude73 is offline
Old 08-31-2013 | 02:31 PM
  #8935
I am using the hot bodies servo horn it works great
lstmuggy is offline
Old 08-31-2013 | 03:04 PM
  #8936
So I just got my eb48.2 together. Measured everything as directed. My front camber even on the outside hole on the steering knuckle is +5*. ! Looks like I'm going to be roasting the outer edges of my tires..... Am I missing something here? Any help is appreciated!
jason248 is offline
Old 08-31-2013 | 03:54 PM
  #8937
T. Herwig's Avatar
http://www.teknorc.com/shop/tkr5252-...rn-24t-spline/
T. Herwig is offline
Old 08-31-2013 | 04:26 PM
  #8938
Cain's Avatar
I use the racers edge ones. You do need to put some sort of riser to get everything level though.
Cain is offline
Old 08-31-2013 | 04:54 PM
  #8939
Graham11's Avatar
Do you have a .1? Hard to tell you without pics, if u post a couple w wheels off I'm sure we could help. And I'm finishing my .2 build tonight so ill let u know if I have same results but this is my 3rd tekno kit in 6 months so i already know where everything goes mostly.
Graham11 is offline
Old 08-31-2013 | 04:57 PM
  #8940
Graham11's Avatar
I use the OFNA seen on the first page which needs 2-3 washers at the link so its level but works great.
Graham11 is offline
