Like Tree2991Likes
1/12 forum
Old 08-28-2013 | 12:37 PM
  #39721
EricF's Avatar
Originally Posted by Nexus
Been away for awhile. ..
Anyone ever use these 1s saddles?
http://www.speedzoneusa.com/estore/i...6a5cf235a83cf4
http://www.redrc.net/2010/01/speedzo...e-saddle-pack/
Was debating firing up my old CRC T-Force using these packs.
I believe that Chris Moore of Phx., AZ. has used them, send him a PM. He has posted on the last couple of pages.
E
EricF is offline
Old 08-30-2013 | 05:33 PM
  #39722
I am new to 12th scale. About to buy my first kit to put together. I have read way back to January on this thread and found some info. What im looking for it what it the 1s speedo of choice right now for 12th scale cars? I have to buy a new one and want to make sure its going to fit and do what it should.
Tigwldr is offline
Old 08-30-2013 | 05:39 PM
  #39723
bertottius's Avatar
Can't go wrong with a Tekin RS Pro or RS Gen 2. Speedpassion makes a good ESC as well.
bertottius is offline
Old 08-30-2013 | 06:22 PM
  #39724
burgboyz's Avatar
SP GT2.1EX is my favorite.
No need for extras like a voltage regulator to clutter up the build.
http://www.speedpassion.net/us/catagory.asp?c=esc&sc=16
burgboyz is offline
Old 08-30-2013 | 06:39 PM
  #39725
Radio Active's Avatar
I've used them. They work well. The capacity isn't as great as the latest cells, but in all other respects I found them comparable to similar stick cells.
Radio Active is offline
Old 08-30-2013 | 07:11 PM
  #39726
RedBullFiXX's Avatar
As your new to 12th scale
It may be worthwhile to have a look at the link in my sig
Lot of info there, including ESC choices
RedBullFiXX is offline
Old 08-30-2013 | 07:41 PM
  #39727
Missing the Viper VTX-1 there
InspGadgt is offline
Old 08-30-2013 | 07:50 PM
  #39728
Updated
Old 08-30-2013 | 09:21 PM
  #39729
The Tekin RS and RS Pro require a booster or receiver battery to work with 1s batteries. Speed Passion's latest ESCs, the Reventon series, also need a booster or receiver pack. SP's GT V2.1 EX will work with a 1s without anything extra.
The Hobbywing v3.1 1s is great, the cap and switch are built into the case. ORCA, Viper and Team Orion also make great 1s speed controls that don't require any booster or receiver pack. Hobbywing also has their original 1s ESC for about $100 or less right now.
avink007 is offline
Old 08-31-2013 | 07:12 AM
  #39730
asc6000's Avatar
Orion http://www.teamorion.com/index.php?d...iew&page_id=44tried the rest and stuck with the best
asc6000 is offline
Old 09-01-2013 | 10:32 PM
  #39731
BoneCrusher's Avatar
Default Duo 2 13.5 Blinky
Anyone by any chance have run a Duo 2 13.5 blinky and have a good setup for motor timing and rollout they found to be pretty fast and stay somewhat cool temperature wise? Using a Hobbywing V3.1 1S Speedo for this.
Thanks,
Ivan
BoneCrusher is offline
Old 09-04-2013 | 05:56 AM
  #39732
Skiddins's Avatar
These questions are mainly to the 1/12 drivers who race outdoors on asphalt;
What tyre compounds have you found best to use?
What additives work on asphalt, and which don't?
Paragon is a no-no, as are any other additives with 'wintergreen'
Skiddins
Skiddins is offline
Old 09-04-2013 | 06:11 AM
  #39733
howardcano's Avatar
Skiddins
For relatively low-traction asphalt, blown off and with sugar water, I ran pink rears and pink (or one step harder) fronts. I also ran them full-size, as it helps with traction, and I'm cheap, so I want maximum life.
Running soft side springs will help with traction. If the surface is very slick, you can leave them out altogether.
Non-detergent 30W motor oil works reasonably well for tire glop, and is very cheap!
howardcano is offline
Old 09-04-2013 | 09:01 AM
  #39734
ScottE1776's Avatar
Skiddins
I'd try Pink rears and Purple front to start. Coppertone or other brand 30 - 50 SPF sunscreen works pretty well for tyre goop.
ScottE1776 is offline
Old 09-04-2013 | 09:19 AM
  #39735
Car Breaker's Avatar
I know Speedmerchant is coming out a rev.8 Who else are coming out of new model this year ?
Car Breaker is offline
