Team Associated B4.2 Thread >
Like Tree4Likes
Old 05-29-2013 | 12:40 PM
  #5641
Skillz_B's Avatar
Originally Posted by 3srcracing
Honestly all three are bling items so depends if you want to spend money to have a BA buggy. The ball studs will help minimize binding but unless your a "pro" you wont notice a difference.
Thanks I was just wondering if were worth the coin or if I should invest in more spares
Skillz_B is offline
Old 05-29-2013 | 12:43 PM
  #5642
Wild Cherry's Avatar
Default TiN Coated ball studs
all you have to do
Just wiggle the Ti rod by hand to notice the difference .
TiN coated studs make for a tighter fit & are smoother to boot .
Wild Cherry is offline
Old 05-29-2013 | 12:54 PM
  #5643
Kellen Guthrie's Avatar
I think the axles are definitely worth it. The stock c clip ones do weird stuff like ruin the bearimgs and such.
Kellen Guthrie is offline
Old 05-29-2013 | 01:34 PM
  #5644
Skillz_B's Avatar
all you have to do
Do you know what size turnbuckle wrench is needed for the Jconcepts turnbuckles?
Skillz_B is offline
Old 05-29-2013 | 01:45 PM
  #5645
mingoglia's Avatar
Here's a link to the wrench. I assume the .143" is the number you're looking for?
http://www.jconcepts.net/store/index...roducts_id=656
mingoglia is offline
Old 05-29-2013 | 01:51 PM
  #5646
Skillz_B's Avatar
Thanks, I guess my google-fu was off, I did a search and couldnt find it.
Skillz_B is offline
Old 05-29-2013 | 03:54 PM
  #5647
im having problems with my car on power is locked in, no on power steering and off power its overkill im running 1.6's all around fr 30 wt and grn rr 27.5 and wht speedo up on the shelf rec under speedo in the tray and shorty w/thick pad up front any help would be great thnx. what im looking for is more on power steering. thnx again
blingy is offline
Old 05-29-2013 | 04:26 PM
  #5648
What front camber link are your running? How many washers? Where are shocks mounted?
Jam-Air is offline
Old 05-29-2013 | 04:41 PM
  #5649
the incubus's Avatar
all you have to do
The best way to diminish slop form turnbuckles is to use these:
These you can tighten down firmly with absolutely no binding whilst still having free movement.
As for regular Ball cups, I'd have to vouch for TLR's silver ones that come on the 22 along with their ball studs. they are very robust and heavy duty and they have a noticeably more precise fit than even the RPM's. If you look inside the Associated and the RPM cups and compare to the TLR ones you will notice how much shinier and slick the TLR versions are. I used a few of these for my buggy up front and the slop diminished significantly but I am swapping them all out for the ones in the pic above for their superior precision and the fact I never have to worry about them popping off.
the incubus is offline
Old 05-29-2013 | 04:51 PM
  #5650
Tradin Paint's Avatar
I used the 1.7 in the rear up till a week ago ..
Cav's set-up uses the 1.6 and 27.5w , its what I have been using now and really like ....
car rides smooth & plush , absorbs bumps really well , landing's & balance very good ...
post 5552 says you have been running 1.4 pistons. Which is it?
Tradin Paint is offline
Old 05-29-2013 | 05:30 PM
  #5651
[QUOTE=the incubus;12203768]The best way to diminish slop form turnbuckles is to use these:
As for regular Ball cups, I'd have to vouch for TLR's silver ones that come on the 22 along with their ball studs. they are very robust and heavy duty and they have a noticeably more precise fit than even the RPM's. If you look inside the Associated and the RPM cups and compare to the TLR ones you will notice how much shinier and slick the TLR versions are. I used a few of these for my buggy up front and the slop diminished significantly but I am swapping them all out for the ones in the pic above for their superior precision and the fact I never have to worry about them popping off.[/QUOTE
Is that all dubro hardware or?
The old school losi grey ball ups are still the best
Jam-Air is offline
Old 05-29-2013 | 05:32 PM
  #5652
He is running the 1.6's in the rear and the 1.4's up front
ManiacMagoo is offline
Old 05-29-2013 | 05:41 PM
  #5653
Front
using the 3 x 1.4 35w green
Rear
2 x 1.6 27.5w white
Old 05-29-2013 | 05:50 PM
  #5654
BLKXJ96's Avatar
Wow, so much to read here and tons of great info. I just got into racing about eight months ago and I seem to learn something new everyday, my biggest problem is learning what to adjust or change to make my buggy handle better under certain conditions. Lots of wheel time and small changes one at a time has helped a lot.
BLKXJ96 is offline
Old 05-29-2013 | 06:35 PM
  #5655
the c/l im running fr 1a w/ 1mm and rr 1b w/none "c"hubs and rear brace shaved and front shock out on arm in on tower and rr in on both
blingy is offline
