TLR 8IGHT E 3.0 THREAD >
Like Tree2Likes
Old 05-08-2013 | 06:54 PM
  #61
spider882009's Avatar
Mine is 90% built. Just waiting on some electronics.
If anyone is looking for a RX-8 & Tekin 1900KV I have one for sale.
spider882009 is offline
Old 05-08-2013 | 07:18 PM
  #62
XXXDad's Avatar
Thumbs up He said it all
Originally Posted by ChrisWolfson
1. everything in the package is used. No mods necessary.
2. use the plastic 45t spur that comes in the conversion.
3. you get a 15 and a 16 tooth. generally the 15 is good in most places.
4. get the orange weller iron. cheap and HOT. i've always used it. here's a link - http://www.amainhobbies.com/product_...FQTd4AodhlcApA
5. you should have enough wire to get it all done with what they send, but if you need more, buy 12 gauge.
Good luck!
I might add that the servo should be on 2 spacers so it does not come in contact with the chassis.
Also no need for the motor spacer at the back it will hit your motor and jack it out of alignment when the chassis flexes. I'm building mine as we speak.
XXXDad is offline
Old 05-09-2013 | 12:14 PM
  #63
Brian C.'s Avatar
For some motors the spacer fits, but not all.
Brian C. is offline
Old 05-09-2013 | 02:56 PM
  #64
ChrisWolfson's Avatar
Looks like you have the right electronics that you are selling! Save a step and just throw that Tekin stuff in!
ChrisWolfson is offline
Old 05-09-2013 | 05:17 PM
  #65
Brian C.'s Avatar
@ spider: Chris is right...
Brian C. is offline
Old 05-09-2013 | 08:16 PM
  #66
XXXDad's Avatar
Questions?? Thats an awsome combo
I would stick with that, what in your mind is better?
Or do you just need a smaller combo because you run indoor??
I'm curious... that's all!
XXXDad is offline
Old 05-10-2013 | 10:48 AM
  #67
guss2009's Avatar
Good luck!
Thanks for the answer. I'm gonna go with the 15t and use the spur gear it came with. I'm also gonna try the solder iron you said. If it doesn't work out ill get a different one. Beside the lipo I have what lipo you guys are using to race with?
I also heard something about not using the motor spacer. I'm thinking about taking it off. I'm almost done just need the 12 gauge wires. Going to pick some up so I can solder these wires
Any other Info would be appreciated. Wheelman your buggy look Great.
guss2009 is offline
Old 05-10-2013 | 11:22 AM
  #68
guss2009's Avatar
How is everyone holding down there tekin Rx8 speed control? Are you guys using double side tape? I also don't know where to hold the on/off switch. There's no instructions on how to install this.
guss2009 is offline
Old 05-10-2013 | 12:05 PM
  #69
I use the Kyosho gel in my scte. It is about 1/4 in thick and gives the speedo a little cushion. It is pricey at 14 bucks for a package but it is reusable if you get it off clean. Just clean it with alcohol and it gets sticky again. I have seen alot of people use reg servo tape and stick it to the side of the speedo.
Rawwolf is offline
Old 05-10-2013 | 12:33 PM
  #70
-WHEELMAN-'s Avatar
The grey 3M tape with red plastic on it is the best IMO. You can get it at Kmart, Walmart, Lowes, Home Depot etc... I just double sided taped my switch to the side of my RX8. I have always done this it works great. Just clean the surfaces where the tape is going before it is applied and it will stick forever.
-WHEELMAN- is offline
Old 05-10-2013 | 01:03 PM
  #71
guss2009's Avatar
Hey Wheelman can you get me a link of the tape your talking about? I have a Walmart or Kmart around my area.
guss2009 is offline
Old 05-10-2013 | 01:13 PM
  #72
XXXDad's Avatar
Thumbs up
I use the clear jell type from hobby shopPARAMA PRO SERVO TAPE 1'X36" SUPER STICK # 8044... it too comes with red plastic cover film. I noticed one member wedged the switch between Batt. holder and RX8 with a tape sandwich not sure if it hangs over in the back of batt tray.
I need to fit it all when it comes.( My RX8) ( With this new method!)
I used to just make 2 holes in side of batt tray and zip tie the switch in because I beat the crap out of my Buggy on the Large outdoor tracks I run on!
OR use shoe goo on the switch stays forever!
XXXDad is offline
Old 05-11-2013 | 08:19 AM
  #73
1badgoat's Avatar
I am using the 3m tape but also take the extra time to drill a couple of holes through the battery tray. I never had an esc come loose with a screw or two holding it to the tray. It pays to take some extra time and route the wires so that they won't get pinched. I add heat shrink anywhere it might rub through the insulation. The Orion switch fits neatly in the little area offset from the main battery area.
1badgoat is offline
Old 05-11-2013 | 08:21 AM
  #74
I use 3m servo double sided tape from wal-mart. I liked the clear stuff, but haven't seen it in awhile. The grey stuff is ok too - it's stronger. Both have a red backing tape.
The trick is to run a big zip tie around the speedo and the speedo tray. That will keep it stuck when the chassis and everything else flexes.
Old 05-12-2013 | 08:29 AM
  #75
smy_dog's Avatar
hi guys im just after your opinion here...
i have a 8ight E 2.0 which is my first buggy and i am looking to upgrade. i am leaning towards the 3.0 as i am a losi fan and have a buttload of spares that can be used on the 3.0
some of you seem concerned about the losi being over priced and also using the old conversion kit.
it is obvious that losi are a more expensive kit anyway so is it seems very unlikely that the price is going to drop or when they bring out the E kit it will be that much cheaper than buying one now and converting?
also when they bring out the E version would it really look,handle or even use any different parts than the nitro kit apart from the conversion? they havent done so in the past so why would they change now?
any reply would be great as i am no expert when it comes to the technical side of things and trying to gather a bit of information before i spend the money.
cheers, peter
smy_dog is offline
