Like Tree5Likes
SC10 4x4 Thread
Old 04-23-2013 | 10:55 AM
  #33841
Cain's Avatar
Originally Posted by foxracer25
I would only run it indoors on a med/low bite track. Dries out fast at times. 40x90 size track most of the time. Always "smooth" with small bumps. But also travel to a very high bite smooth track that's quite large. Just curious on the upgrades that would be good ideas to run.
I would probably start with the M2C toe in block for sure.
Cain is offline
Old 04-23-2013 | 01:44 PM
  #33842
Jordan Anderson's Avatar
Originally Posted by Cain
If its loose, bumpy 1/8 track, I can recommend the following based on experiences with the vehicle:
- M2C Rear Toe in block or similar to get more toe-in
- RC Shox Center Diff (you may like the exotek locker though)
- Exotek Chassis
- RC Shox Dual stage pistons
- Front springs to use on rear as needed
What's a good starting shock setup (oil/pistons/springs) when using front springs on the rear?
Jordan Anderson is offline
Old 04-23-2013 | 02:07 PM
  #33843
Cain's Avatar
send me a pm with your email address and I'll sent you the setup I used for loose conditions.
It uses pretty much all the stuff I mentioned, in particular the RC Shox pistons. For stock pistons, not sure however.
Cain is offline
Old 04-23-2013 | 04:57 PM
  #33844
Wild Cherry's Avatar
go to www.rc10.com
Click on setups
Use John Walentia's Show Down .
By the sound of your conditions maybe try blue rear spring instead of yellow..
You don't need to buy much extra.
B4 C Hub for sure you will need.
Wild Cherry is offline
Old 04-23-2013 | 05:12 PM
  #33845
How are they mounting the C hub on? Drill new holes and mount flush to the hub? Is there any pictures explaining the "right" way of doing it?
foxracer25 is offline
Old 04-24-2013 | 11:17 AM
  #33846
TomErickson's Avatar
Does anyone have insight into Chad Due's set-up from Trackside hobbys last weekend?
TomErickson is offline
Old 04-24-2013 | 02:58 PM
  #33847
Default used roller question
i purchased a roller recently and I'm wondering if i should do a tear down on the whole truck? when i got it i noticed that the front wheels weren't spinning smooth due to a front screw pushing on the front clicker. I'm still waiting on electronics and I'd like to know if there is anything wrong with the truck before i run it. i wouldn't want to do more damage before i get to run it. but on the other hand i want to see how the truck runs before i tear it apart. is there any important things i should look at before i do anything with it? i currently run a 2wd sc10 and i have worked on that. so I'm pretty comfortable working on my own truck. any information would be helpful. thanks.
dppfi is offline
Old 04-24-2013 | 03:37 PM
  #33848
Cain's Avatar
Yes, always do that in my opinion on any used items you purchase.
Cain is offline
Old 04-24-2013 | 04:21 PM
  #33849
thanks for the information.
dppfi is offline
Old 04-24-2013 | 04:47 PM
  #33850
dppfi
Can down load the instruction manual at www.rc10.com
measure & compare the screws so you know all are the correct size when you overhaul.
Very common to find incorrect size used .
Old 04-24-2013 | 07:19 PM
  #33851
???E-Racer's Avatar
What some of you have been waiting for is me racing my 4wd SC10 this weekend.
If the weather is clear and no more rain is on the horizon I plan on racing.
???E-Racer is offline
Old 04-24-2013 | 09:00 PM
  #33852
dppfi
Can down load the instruction manual at rc10.com
I will definitely keep a close eye on all the bolt sizes. Thanks again for the info.
dppfi is offline
Old 04-25-2013 | 02:25 AM
  #33853
Fredp1's Avatar
Default sc 10 4x4 90004 vs 90010
Hi,
There are 2 versions of the FT kit. A discontinued kit 90004, (selling quite cheaply) and the current kit 90010.
Other than the body, whats the difference between the 2?
Fred
Fredp1 is offline
Old 04-25-2013 | 07:36 AM
  #33854
drolmaeye's Avatar
Originally Posted by Fredp1
Hi,
Fred
90004 is the basic (original) kit, not the FT kit. 90010 is the FT kit which comes with stuff like hardened shocks, Ti turnbuckles, chassis brace, VTS slipper, etc. If you want to go with a kit I would strongly recommend ASC90010, the FT kit.
drolmaeye is offline
Old 04-25-2013 | 07:54 AM
  #33855
Fredp1's Avatar
Ah.. Thanks for pointing the difference out.
Fredp1 is offline
