Like Tree1Likes
Hudy Break In Bench
Old 02-26-2016 | 07:01 AM
  #46
Looking for some help and/or suggestions. I have the Hudy break in bench and have used it many times without issue. The last couple times I have used it, the motors have been hard to start. I use a Hobbico Torqmaster 180 to turn the prop. I have checked many things and I feel like it's either the Hobbico has lost power or maybe the rubber insert has lost its grip. Any suggestions or ideas would be greatly appreciated.
jay5280 is offline
Old 02-26-2016 | 06:00 PM
  #47
grizz1's Avatar
Is the starter just stalling, or is the rubber slipping on the prop ?
Also are the engines the same brand as you have been running in before - or different ?
There is a huge discrepancy in the "tightness" of new engines from make to make.
I'm guessing your pre heating the engines before starting ?
Is it possible that whatever you are using to heat the engines is not working properly anymore.......
Not properly heated a new engine will be a struggle no matter what starting system your using.
grizz1 is offline
Old 02-27-2016 | 02:27 AM
  #48
Heat up the engine before the start.
Roelof is online now
Old 01-17-2019 | 10:34 PM
  #49
Any one who stil uses this method?
Or is it only oil bath break in?
Houmb is offline
Old 01-19-2019 | 10:00 PM
  #50
Once you've done EBIS, it's impossible to go back. 2nd choice would be Hudy bench (I still have one), 3rd choice would be in the car.
stephen_bess is offline
Old 01-19-2019 | 11:39 PM
  #51
am
Hei
Trenger du innkjøring er det bare å si ifra. Har laget meg en oljebenk :-)
Anders M
Houmb likes this.
am is offline
Old 04-23-2020 | 08:05 PM
  #52
Tim W.'s Avatar
Really thinking about getting one of these cause I hate doing the in car method and with all the time we have on our hands now what fun is the ebis lol! Anyone still using them?
Tim W. is offline
Old 06-10-2021 | 02:01 AM
  #53
Default Spinner (propeller locking nut)
Hi hope someone can help.
The spinner (nut) that secures the propeller to the crankshaft keeps coming loose. I'm using a crankshaft locking tool so at time of assembly it's tight.
I'm using an electric drill with a max rpm of 2000 (in reverse).
After a lengthier bursts with the drill (5 secs) the spinner comes loose.
Anyone experience this? And more importantly what did you do to correct.
Thanks in advance.
WhisperJim is offline
