Team Associated B4.2 Thread
#3797
Currently we are at 17-18 second laps. Last layout we were at 15 second laps. We had a layout a while back that we were getting 13 second laps (1/8 were only hitting 12
#3798
Just seemed like they made a few fundamental errors. Maybe someone else built the jumps, maybe they just need to get back into the swing of things after winter, either way it could be better, but I have witnessed worse.
On a more thread specific note, your car did seem to do pretty well with all the flat landings. Big bores really help with that huh?
The big bores are a godsend out there. I was running 1.7 37.5 / 35 but with the temp drop, it was prolly like 5 wt heavier LOL. I am going to try the 1.6's this weekend and eventually the tapered pistons.
Fast laps on the track so far for 2wd were done by Gunnar, he hit a few low 27's. I think Francis hit mid 27's. I hit high 28's. I suspect when groove comes up, you'll see lap times in the 26's with 4wd mod dipping into 25's.
#3799
Our only indoor track 2wd usual times is 14, super fast is 13. 4wds hit 12's. we just changed the track so will see new times this Tuesday.
#3801
stays more consistent run after run...
It can be adjusted looser and still delivers great punch ...
The VTS has to be cleaned after three to four races where the Triad can go many races before cleaning ..
#3802
No complaints with my triad so far and i have ran it for a long time now about since its been out, on the original pads and plates, Never really needs adjusting after its set. I pretty much dont even check it anymore before a run, maybe once when i get to the track but i have found its not necessary since it doesnt seem to get out of adjustment.
When i do check it, its very quick blurps with the throttle and as long as it lifts about 2 inches im happy with the setting. I do not hold the throttle on and overheat it and if i did it would go higher then 2 inches with how they work.
#3803
If you run stock classes try the MIP lightened top shaft too..
i did the maths last year it equates to about a 23% decrease in rotating mass of the transmission. we have a 40 m straight at our club and this gave me the ability to run 69/35 gearing with a fantom ion 3 17.5.... had the fastest car by a long way! and with a motor that was always way way under temp
#3804
I got my B4.2 friday night and had it built saturday morning! First race with it was Sat evening! I have to say, it has been 2 years since I wheeled a buggy and the last 2 years have been racing ST and SCT primarily so my driving skills were horrendous... That being said the buggy was tremendous! I had an ear to ear grin every time I was on the stand! It jumps, turns, you name it does it well!!! I am running box stock setup except I shaved the u brace and switched to avid shock pistons. Love it! I will be focusing on the buggy as much as possible and racing the ST now and then... Poor 22SCT is gonna sit for a while!
#3805
Anyone that can help me?
Posted it also in the big bore section but got no responds.
Anyone that has a good (shock) setup for an outdoor track with small jumps but pretty bumpy.
With a layer of dust on it. also some parts are carpet/astro.
Goosebumps rear with groovy green up front worked pretty good.
But could use some more steering in the 180° degree corners.
The rear of the car might need some heavier oil, it's bouncing a bit.
I'm now running the stock setup from the B4.2
Some pictures:
Some pictures:
#3807
Some pictures:
Some pictures:
#3809
#3810
4Likes
