Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-19-2013 | 05:36 AM
  #3091
Originally Posted by Venom1836
Question:
How much harder is a Gold JC Tire Compared to a Green JC Tire?
Or are they both for completely different surfaces?
Everyone who runs Gold says they last forever, and Green guys say they dont last long
I have used Gold on indoor clay. The green was for outside on dirt. Atleast that is what I always thought. On carpet they both wear fast.
Ivegotklas is offline
Old 03-19-2013 | 05:57 AM
  #3092
I ran the ESC in the tray on a low bite track this past weekend and it was ok. I went faster than the week before but I think that was more because of better tire choice. I'll be on a medium bite track this weekend that I'm more familiar with. I should be able to see how it effected it more after that. As long as it doesn't make it worse, I'm keeping it. I cut a ton of weight due to less wiring, and it looks cooler, which as everyone knows, is the most important part of racing
Bob Barry is offline
Old 03-19-2013 | 06:43 AM
  #3093
snowman_evil's Avatar
For those running the ESC in the battery tray how are you finding it? What setup changes did you find necessary to meet the same feel as what you had before you moved the ESC there?
snowman_evil is offline
Old 03-19-2013 | 08:06 AM
  #3094
I didn't change anything, and don't plan on changing anything. The whole point is to make the car transition quicker side to side through the turns. If it was too much then I guess I would increase dampening to slow it down some, but I can't see it being too much.
Old 03-19-2013 | 08:11 AM
  #3095
Wildcat1971's Avatar
Tech Prophet
why would you move the esc to have it handle the same? The whole point is to make a change to the cars handling. Why make a change only to zero it out?
Wildcat1971 is offline
Old 03-19-2013 | 08:14 AM
  #3096
Wild Cherry's Avatar
Originally Posted by Ivegotklas
I have used Gold on indoor clay. The green was for outside on dirt. .
Wild Cherry is offline
Old 03-19-2013 | 08:15 AM
  #3097
Tech Prophet
A new setup was posted on the AE site. It is pretty standard, but does use the 1.4 pistons and a longer rear link.
http://teamassociated.com/pdf/cars_a...ands_TNS_6.pdf
Old 03-19-2013 | 08:33 AM
  #3098
tedstryker's Avatar
After running my 210 all winter ....its time to go back to the car that got me in the winner circle..
tedstryker is offline
Old 03-19-2013 | 08:56 AM
  #3099
Tech Prophet
I looked at the dex210. I read and read and talked to people, then decided it was a bad idea. Then a local bought one after he tried the B4.1 and the TLR22, I can say for sure that he lost an entire lap with the dex210, when he was not broken. And he rarely crashes and our track is like racing on pillows. very spongy clay. I have never seen a car fall apart as much as the 210. The dex410r v3, seems to be the opposite and very good though.
Old 03-19-2013 | 09:44 AM
  #3100
Is there a "carbon" 9572 and 9568? Thanks!
NovaCX12 is offline
Old 03-19-2013 | 09:52 AM
  #3101
carbon front tower #9569
carbon rear tower #9573 ( does not have the 4th hole and will need to drill)
Old 03-19-2013 | 10:00 AM
  #3102
Are these the ones you have to modify for the Big Bores that come with the 4.2?
"This is an optional Team Associated Carbon Front Shock Tower, and is intended for use with the Team Associated B4 line of 1/10 scale buggies. This shock tower requires modifications if you are using it with the optional Team Associated 12mm Big Bore Shocks"
NovaCX12 is offline
Old 03-19-2013 | 10:02 AM
  #3103
Nova
Need to grind the carbon tower's for the 12mm BB to fit or use shims for making clearance...
Old 03-19-2013 | 10:11 AM
  #3104
Nova
Thanks, I'll skip those for now. How does this look besides electronics?
NovaCX12 is offline
Old 03-19-2013 | 10:17 AM
  #3105
jf+'s Avatar
jf+
Thanks, I'll skip those for now. How does look besides electronics?
I think the wing mounts are kind of a waste. The carbon parts are a matter of preference. I'd drive with the regular ones for a good while before swapping them out. Also, it depends how you drive. If you're sloppy, you'll break them pretty quickly.
As always, I recommend the RPM front bumper, too.
jf+ is offline
