Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 02-26-2013 | 09:56 AM
  #5821
Originally Posted by Outtacontrol58
I have both vehicles as well. What makes the sct410 diffs better !?! My front and rear on my EB is leaking so I'm about to go through the car. Thanks for any info
I'm curios about this also.
Pinebox is offline
Old 02-26-2013 | 10:15 AM
  #5822
sickpuppy1's Avatar
Originally Posted by rcbo
They one I had on my losi would not work.The arm has to fit between servo and horn.
Thats why I specified this particular arm. A standard Losi servo arm comes straight out off the servo and will not give enough room between the arm and the servo for the link, your right. This 22 servo arm curves up away from the servo to make room for a link. I'll try to take a pic.
sickpuppy1 is offline
Old 02-26-2013 | 10:16 AM
  #5823
FRONTI3R's Avatar
The gears are lighter and the cross pins are bigger then the ones in the EB48. The case is the same but TeknoRC suggested you also replace it for a clean start.
FRONTI3R is offline
Old 02-26-2013 | 10:19 AM
  #5824
Originally Posted by UK.hardcore
Between the clutch bell and the axle its on.
with traction drive it's easier too see how much it needs before you put it all together because the shoes put pressure on the bell.
Red circle on picture is where the shims go if needed.
They go under the screw? I put the 1.1mm springs in. I don't know how much play it has. The clutches grab onto the bell. I'll just add a shim for the heck of it.
rallyredevo is offline
Old 02-26-2013 | 10:32 AM
  #5825
Tekno thanks for the amazing cars my eb48 and my sct410 make me look way better then I realy am.
jt409 is offline
Old 02-26-2013 | 10:46 AM
  #5826
teknorc's Avatar
The gears are a slightly different design and run smoother than the EB48 gears. Also the crosspins on the SCT diffs have squared ends so they slot into the diff case. This virtually eliminates the possibility of a diff failure since the pins can't dig in to the case and dork the mesh. As a result, the diffs run cooler and stay more consistent while being more durable.
If you're going to replace the diffs in the EB48, definitely replace them with the newer diff parts (TKR5149, TKR5150). The case is the same, but we suggest replacing those as well.
teknorc is offline
Old 02-26-2013 | 10:54 AM
  #5827
Crawlin's Avatar
After looking on the first page, that diff "issue" is all solved now correct in the newer kits?
Also, are blank pistons available anywhere? Or just those "option" parts that are predrilled?
also, do you sell a spring KIT that has all of them? just looking to see if $150 in springs is really the cost to get all of them for a full tuning option by buying at $10/each
and what body is on the truck on the first page?
Thanks so much for all the help
Crawlin is offline
Old 02-26-2013 | 11:53 AM
  #5828
sramos's Avatar
wow!!! imagine using (if possible) on your cars, chassis, plastics etc.... would it work......gotta check this out!!!
+ YouTube Video
sramos is offline
Old 02-26-2013 | 12:02 PM
  #5829
boudin4evr's Avatar
+ YouTube Video
that stuff is amazing!
boudin4evr is offline
Old 02-26-2013 | 01:07 PM
  #5830
jones8352's Avatar
Default trimming weight
I'm trimming a little weight off of my 410. Today I swapped chassis's with my eb, plus I should be getting some lighter parts tomorrow. I ordered some Tekno light weight parts and the Durango orange aluminum links. I thought the aluminum would be a little lighter plus I like the color. Does any body have a ball park idea of how much lighter the aluminum steering and caster rods are? I decided to go with a lighter battery, I ordered a couple of Protek shorty packs that weigh in at 219g and they're 4100mah which is fine for my indoor racing. The battery knocks the weight way down close to 80g compared to the one I was using.
jones8352 is offline
Old 02-26-2013 | 01:18 PM
  #5831
sramos's Avatar
i know right!!!! i imagine it'd be really good for nitro especially, with all that fuel and dirt sticking everywhere......what about in diffs and stuff too? maybe no more leaks.....or shock cap threads, or cartridge area......i mean the stuff looks pretty awesome....wonder how long it would last.....seems to good to be true LOL
sramos is offline
Old 02-26-2013 | 01:26 PM
  #5832
timannnn6's Avatar
What about tires? Would it keep dirt/mud from sticking? Probably wear off too quick.
timannnn6 is offline
Old 02-26-2013 | 02:31 PM
  #5833
racerob1983's Avatar
Default Just ordered truck
What parts have you guys been breaking i would like to buy some spares...
racerob1983 is offline
Old 02-26-2013 | 02:41 PM
  #5834
Cappy's Avatar
Truck is built like a brick $#!t house !!! Parts wont be breakin very easy unless you flat out abuse the thing !!
But just to be safe its always good to have extra A arms steering spindles rear axle hubs...
also not a bad idea to have an extra spur gear...
Cappy is offline
Old 02-26-2013 | 02:50 PM
  #5835
sramos's Avatar
i dont know man. seems like a paint of sorts......a base coat then some other coat....2 parts. says it dries translucent white. havent read to much into it. so would dry stuff like dust and stuff stick or does it just repel wet stuff. i know it shows concrete in the video, thats sort of gritty. crazy stuff. i would assume it would seal stuff like diff cases etc.....not letting oil pass.....all and all i have no idea LOL
sramos is offline
