Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 02-17-2013 | 02:01 PM
  #4936
Originally Posted by Bernard_Jr
Another TQ and win at Newred Hobbies last night (high bite, small, clay indoor track 18+ sec laps).
To start, I was still running stock shock oils/springs/positions, stock diff oils, 100mm front & 120mm rear droop, 26mm front 25mm rear height, no center/rear brace, and hubs forward one thick spacer. This is the setup I used at the medium indoor track. I replaced the front tires due to excessive wear and left the slightly worn rears on.
Truck slid out through the turns. The only changes I made before racing started was moving the hubs forward to two thick spacers and replacing the one race old tires in the rear with fresh tires.
The truck still slid out slightly in a high speed curve. I just applied more throttle and it pulled through every time.
I had the SSC Traxxas developer Mark hot on my heals in qualifying only 2 seconds behind. The truck was excellent all day and pushed it in the main to a sizeable lead. I think it's level jumping and controlled breaking really made the difference.
At the end of the day the front tires were toast again. It's clear a thicker oil is needed in the center diff. My question for you guys is how even do you think the front/rear tire wear should be?
I haven't ran my Tekno much yet but my Durango is usually 2 sets of fronts to 1 set of rears, and same with my Ofna TS-4
flraptor07 is offline
Old 02-17-2013 | 02:03 PM
  #4937
jones8352's Avatar
Originally Posted by flraptor07
I got the chassis all done but my body didn't get here so I couldn't race it this weekend. But here's some pics of the completed chassis, set up stock just as they said in the destructions. With a Hobbywing SCT Pro C1 4700 combo, Savox SC-1256TG servo, Futaba R2104GF reciever, and the new Vant 6200mAh 60c batteries. Dirt Cheap RC has a hell deal on these $47.99Attachment 1032786
Attachment 1032787
Attachment 1032788
Attachment 1032789
I'm running the same motor and same servo, man you're in for a treat!!!!
jones8352 is offline
Old 02-17-2013 | 02:14 PM
  #4938
jones8352's Avatar
Default Sad day at the track (minor)!
I received my 17mm adapters from Tekno earlier this week and finally had a chance to try them out today. About five mins into the first pack I came off a small jump and the right rear wheel came off. The nut was still on the insert had broken. It was kind of odd I sure hope this was a freak thing not needing to be made out of aluminum to be strong enough. That would shoot the price up quite a bit. Tekno I sent you an email. I put one off of the front wheel in the pic for comparison.
Old 02-17-2013 | 02:25 PM
  #4939
Originally Posted by traxxasrockhead
Well thinking on getting the bad boy or the losi scte what do you guys think and as for motor recomendation what do you guys recomend and what gearing?
When you post a question like that on this forum I don't believe you're going to get an unbiased opinion but here's my best shot at an answer.
I just bought my 410 last week, it won't even arrive until Tuesday,after doing a lot of comparison shopping. Only two other trucks are in the running The Durango and the SCTE 2.0.
The Durango is a fast, great handeling truck but unfortunately it has a reputation for being rather fragile. That's a deal breaker for me. I don't mind spending money to buy a good truck and to get it set up for racing, but I don't want to have to spend big bucks to keep a ton of spares on hand so I can repair it. I hate to DNF a race then have to spend my time between races wrenching like crazy to get the truck repaired for the the next heat. Good truck, but not for me.
The SCTE 2.0 isn't a new truck. Basically it's the same truck with all the features of a $700 hopped up race truck. Smart move on Losi's part. Why try to reinvent the wheel when after market companies and the racers have already shown you what needs to be done to make a ARR truck into a full blown race version. From the videos I've watched it appears that Losi has done a nice job on the version 2.0, but I don't see anything that will make it significantly better than the hopped up versions of the 1.0.
Now the Techno is an all new truck and from all reports Techno has hit a bullseye with their first shot!! The truck is rugged as you might expect since 80% of it's parts come from a 1/8 scale buggy. It handels great. It's light. Techno's support is great. Most importantly it's ready to race right out of the box with the only add on really needed being aluminum hexs availble for less than $20. There are options available, but they aren't required to take it out of the box and win races with it. I'm not sure what more you could expect from a truck kit. I know it hits all my hot buttons and that's why I have one on it's way to me right now.
virgilj is offline
Old 02-17-2013 | 02:30 PM
  #4940
Wanted to mention that last weekend at the Cabin Fever race qualified 5th and took 5th overall with the sct410 truck worked awesome and it was a awesome huge arena cross style track I was the only Tekno there.
umpy907 is offline
Old 02-17-2013 | 02:38 PM
  #4941
jones8352's Avatar
Default esc fans
I recently had my computer crash and I lost a lot of info. Can any body give a link to a site that sells quality esc fan replacments? Most of the time I use Castle esc's, good esc but crappy fan motors.
Old 02-17-2013 | 03:59 PM
  #4942
I got to race on a large 1/8th track at Motorama this weekend. I beat the crap out of it and it handled everything like a champ! started in the C main and bumped into the B main. Now if only the driver could keep up with the truck.
mdmaxx is offline
Old 02-17-2013 | 04:05 PM
  #4943
That's a bummer. I was thinking of picking up these adapters to run the DE 17mm wheels but that kinda has me worried. I guess if enough of them fail then Tekno might make some aluminum ones.
MattP is offline
Old 02-17-2013 | 04:09 PM
  #4944
How was Motorama this year? I was hoping to be able to make it but I couldn't. They have a good turnout again this year?
MattP is offline
Old 02-17-2013 | 04:30 PM
  #4945
jones8352's Avatar
I'm hoping it's a freak thing but imo after close inspection I really think the part is too thin. But I didn't design it so I don't know for sure. I hope it was a freak thing, $9.99 is a great price for 17mm adapters. The aluminum ones on the market that are held on with a nut are a big pain and are spendy. I really like the Tekno adapters, basic simple and cheap now it's just a matter of finding out why they broke so easy. I did try to put a metal washer under the wheel nut but that didn't work very good. You could only get about half of the threads on the nut. I'm confindent that Tekno will figure out the problem, I sure like the idea of using my 1/8 buggy wheels for practice, got a ton of them. Maybe not a ton but 50+ sets. Yea I know I'm a rc junkie!!! Hehehehehe
Old 02-17-2013 | 04:32 PM
  #4946
It was great. XRC built the track and took care of it through out the weekend. the turnout was great.
Scotty kept everything moving. I would say it was the best rama yet and I only missed 1. From what the XRC guys said they will be building the track for next years rama also. good times were had!
mdmaxx is offline
Old 02-17-2013 | 04:35 PM
  #4947
I'm like you Jones as I have a ton of buggy tires as well I could be using for practice.
That's cool that Motorama was a hit again this year. I will definitely have to make it next year.
MattP is offline
Old 02-17-2013 | 04:46 PM
  #4948
gangstafish's Avatar
Mr Tekno, Your website seems to not be working. I tried to place an order for parts for this truck and it is not working. It keeps saying something about invalid credit card numbers,but there is no where to put a cc number when I order. It is really frustrating.
gangstafish is offline
Old 02-17-2013 | 04:52 PM
  #4949
jones8352's Avatar
My wife thinks I have more buggy and truggy tires than any body on the planet. Close but not true. Today I was running a 1/8 set of Pro-line Caliburs m3 compound, they were hooked up so good. I was racing - practicing against a couple of 1/8 Losi buggies plus a Losi e-truggy and having a great time. Normaly a sc truck wouldn't stay close to this gang of bandits. These guys are fast, they were amazed that the 410 could hang with them. This is my first season in 1/10 racing and I'm super happy with it. I've been into 1/8 but in my area you have to drive a long ways to race. So it's real nice to race closer to home.
Old 02-17-2013 | 04:58 PM
  #4950
I picked up one of the 4000kv 3656 Hobby Wing motors. What would be a good baseline gear for a tight track with the longest straight being 75'? 16t ?
MX304 is offline
