Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 01-29-2013 | 08:02 PM
  #3271
Slotmachine's Avatar
From what I observed the 4 o-rings on the shock shafts keeps the universals from hitting the diff-out drives on full compression. (when you happen to land on one wheel and compress fully) This is something that Associated told owners to do to keep the diffs from leaking.
Slotmachine is offline
Old 01-29-2013 | 08:06 PM
  #3272
symmetricon's Avatar
To keep the from roasting. Lol
symmetricon is offline
Old 01-29-2013 | 08:18 PM
  #3273
Yes ...I roasted a few myself. But now I own the best SC Truck on the market
Old 01-29-2013 | 08:19 PM
  #3274
The truth has never been clearer.
Old 01-29-2013 | 08:37 PM
  #3275
sramos's Avatar
+1000000
sramos is offline
Old 01-29-2013 | 08:38 PM
  #3276
now i know i wont be buying the aluminum towers ill be waiting for the CF towers , What is the best spring kit to order to have some spring options for this truck, i have read the AE springs will not work.
tmaxxfreek is offline
Old 01-29-2013 | 08:49 PM
  #3277
teknorc's Avatar
There was an explanation a few pages back. The driveshafts should not hit the outdrives even without the bump-stops (full travel). The o-rings were added because the car handled better in most conditions.
teknorc is offline
Old 01-29-2013 | 09:34 PM
  #3278
cpt_RedBeard's Avatar
+1 a spring kit would be nice. So would a sway bar kit.
cpt_RedBeard is offline
Old 01-29-2013 | 09:42 PM
  #3279
Cain's Avatar
AE rear springs are too long for the rear of the vehicle. The front springs however appear to work as if I recall correctly they are 70mm . I use them on the front of mine, so far so good.
I went ahead and ordered a bunch of Hot bodies springs.
Cain is offline
Old 01-29-2013 | 11:53 PM
  #3280
Acill's Avatar
I got mine nearly together at last. I just to to solder up my motor and do some fine tuning.
Acill is offline
Old 01-30-2013 | 12:49 AM
  #3281
That's the same combo I have, and for some reason something's major wrong with mine atm. Gutting my RC8 for a new RX8 and Pro 4 going in till I can pinpoint the problem.
Car was guttless, and way weird to drive. Everyone felt wrong. Came straight out of my Sc10 4x4 and was the fastest car at the track. Goes into this car, and it's a POS. So confused.
SC Shaun is offline
Old 01-30-2013 | 12:54 AM
  #3282
Matthew_Armeni's Avatar
Very weird. Have to ask, did you re-calibrate all your gear? I'm sure you'll figure it out, it's probably some minor detail.
Matthew_Armeni is offline
Old 01-30-2013 | 01:02 AM
  #3283
Re-calibrated (12 times throughout this)
Opened motor, cleaned
New sensor wire
checked solders
rebound radio
EPA play
Timing did absolutely nothing
I was having to run a 20t pinion just to kind of have the speed of my buddy who's running a pro 4 with a 13t. Major weird.
SC Shaun is offline
Old 01-30-2013 | 02:04 AM
  #3284
Pro4 should fix it. I felt the SC4X was down on power in my Losi. A 4-pole 540 motor fixed that.
You are going from a light truck on a low-horsepower layout, to a heavy truck on a high-horsepower layout.
I'm running a 4800 kv 4-pole w/ 14T pinion and it's not running out of gear on the straight w/ 16 degrees boost timing (0 can timing). A 20T pinon seems like it would be too tall for a 4.5T motor.
rallyredevo is offline
Old 01-30-2013 | 06:04 AM
  #3285
AMain from this past Sunday. That's me in the dark green hoodie, closest to the camera on the stand. I start dead last, bright green/white, yellow 22SCT wheels.
+ YouTube Video
NitroOB4You is offline
