MTX 5
Old 01-12-2013 | 10:38 AM
  #2626
bigbank66's Avatar
Doctor...explain how u do that??? I always have to take everything off to access the diffs....
bigbank66 is offline
Old 01-12-2013 | 11:44 AM
  #2627
doctormtx5's Avatar
sure..
1. take off middle shaft bracket (releases belt)
2. take out forward clip on fuel tank
3. take off steering rod holder
4. take off shocks
5. take off antiroll bar holder and anti roll bar
6. take off front bumber assembly and disconnect both front upright's
7. take off the forward most outer screwes on the upper deck. (this releases the upper arms)
8. take off front upper arms
now you should be able to slide off the plastic bearing holders.. then proceed to slide off the bearings from the diff to the side.. like you did the plastic bearing holders... then you can pull out the front diff.
you dont even need to remove engine or disconnect steering assembly.. If you wanted to change the front belt too, all you would need to do is disconnect one of the steering arms.. hope this helps.. message me if you want a picture to go along with this
doctormtx5 is offline
Old 01-12-2013 | 12:57 PM
  #2628
shanwright's Avatar
Originally Posted by doctormtx5
sure..
4. take off shocks
All that in 5 minutes? And put back together I'd love to see a you tube clip of that. . I reckon it's a good 15 minutes .
But getting back to my point, I've been running plastic fronts for a whole season and no problems. Just wondered how others had got on.
Steve H.
shanwright is offline
Old 01-12-2013 | 02:07 PM
  #2629
doctormtx5's Avatar
Steve H.
Yes 5 to 10min.. All depending how comfortable you are with the car. everything is easy to access And work on. I replace gears when needed. But always before main.
Old 01-12-2013 | 02:27 PM
  #2630
NITTO550's Avatar
Steve H.
+1 , it's a easy 15 min, 20-30 on the nt1.
Plastic fronts all the way.
NITTO550 is offline
Old 01-12-2013 | 08:30 PM
  #2631
we have run plastic gears /kit/ones in front diff since new onley changed oil twice so one set has done 2 NSW titles 3 QLD/1 nats +club days so they are lasting now they will strip for shore
greg
I can never get dam bearings off the diff so I just pull one side of like 4r I wish it took 5 mim
greg.dawn is offline
Old 01-21-2013 | 12:35 AM
  #2632
Hi All.
What´s your feedback about the new Mugen parts (Chassis, engine mount, spurs)?
Does it solve the stripping problems comletely? If so... Just the engine mount (?) or Mount/chassis, or monut/chassis/spurs?
Thanks in advance.
Luís cortez
Luís Cortez is offline
Old 01-22-2013 | 11:51 AM
  #2633
Perez's Avatar
Originally Posted by Luís Cortez
Hi All.
Thanks in advance.
Luís cortez
I think the new parts are great! If you scroll through the pages you will see that the new parts have helped with the stripping.
I am using both the new chasis and the engine mount and have yet to strip a gear ( about two hours of run time so far).
Hope this helps,
Steve
Perez is offline
Old 01-22-2013 | 04:57 PM
  #2634
shanwright's Avatar
Hope this helps,
Steve
So are you using the new gears too.
Because I have heard the old ones are fine with the other fixes.
Steve h
Old 01-22-2013 | 08:11 PM
  #2635
NITTO550's Avatar
I'm was using the old gears last season, as long as you do the fixes, old gears are fine. If you don't make the proper corrections, new gears will strip as well. Can't wait to start her up, just a few more months and ill be back in action.!
NITTO550 is offline
Old 01-23-2013 | 02:56 AM
  #2636
Now that the problem seems to be solved, with original Mugen parts, next step will be to see, if and how, this changes (harder chassis...) will affect the excelent handeling of the car.
Best regards.
Luís
Old 01-23-2013 | 03:18 AM
  #2637
djiewie's Avatar
5 min on the NT1 both front and rear
6 screws front and 6 screws rear thats all.
djiewie is offline
Old 01-23-2013 | 12:02 PM
  #2638
Perez's Avatar
Have any of you guys run with a shorter wheel base. I have been hearing that some racers , especially overseas, are cutting front and rear arms 1 mm shorter for better turning on tight corners or smaller tracks.
Any one try this?
Perez is offline
Old 01-23-2013 | 05:57 PM
  #2639
NITTO550's Avatar
The rear on the nt1 was easy but that front belt was always a pain in the as* for me especially the eccentric bushings for Adjusting the belt tension. Always took me 20-30 for a front belt. , but what do I know
NITTO550 is offline
Old 01-23-2013 | 08:26 PM
  #2640
gotmotor's Avatar
Any one try this?
I have I have and it works great
gotmotor is offline
