RC10B4.1 FT/WC
Old 01-23-2013 | 06:12 PM
  #27721
vito's Avatar
what shock oil comes with the wordls kit thanks
vito is offline
Old 01-23-2013 | 06:30 PM
  #27722
Strawberry
Bob Barry is offline
Old 01-23-2013 | 06:35 PM
  #27723
Matt Trimmings's Avatar
Snozberry
Attached Thumbnails RC10B4.1 FT/WC-images.jpg
Matt Trimmings is offline
Old 01-23-2013 | 06:37 PM
  #27724
Wildcat1971's Avatar
Tech Prophet
30wt
Wildcat1971 is offline
Old 01-23-2013 | 06:39 PM
  #27725
Cridd's Avatar
Originally Posted by mashimarowu
Blinky is when your ESC is blinking literally. Meaning no boost/timing is added via the ESC.
Full stock means your not running extra stuff on your esc settings so it blinks to let everybody know your not cheating
Cridd is offline
Old 01-23-2013 | 09:18 PM
  #27726
vito's Avatar
what size hexs i need tips
vito is offline
Old 01-23-2013 | 09:20 PM
  #27727
vito's Avatar
it shipped out now ill have it nexts week
vito is offline
Old 01-23-2013 | 09:22 PM
  #27728
Standard.....look in the manual, it shows exactly what is needed to build the kit.
Old 01-23-2013 | 09:25 PM
  #27729
mashimarowu's Avatar
typical 12mm hexes...
mashimarowu is offline
Old 01-23-2013 | 10:46 PM
  #27730
.050, 1/16", 3/32". Those three cover it all.
associatevalley is offline
Old 01-24-2013 | 12:46 AM
  #27731
Kellen Guthrie's Avatar
Maybe a 5/64" for the diff screw and 4 others on the underside of the rear part of the chassis??
Kellen Guthrie is offline
Old 01-24-2013 | 06:26 AM
  #27732
vfrninja's Avatar
Originally Posted by Jeckler
I disagree with Walfet. It's the combo of a high power servo, an ESC that can't provide it and Spektrum's minimum voltage requirements.
The rx doesn't provide any power to anything, that's the ESC's job. It simply uses it, like the servo. The +&- pins in most rx's are bridged. Think of it as an internal y-connector.
When power demand is higher than the ESC can provide, voltage drops. It's this drop that causes the brownout (the rx "reboots"). I use a 1258 with a BH120 and an SR300. I use a cap because of the power requirements of the Savox servo. I had 3 brownouts before the cap, none after. It's not the end-all, be-all, but it works for me.
I would still get brownouts with a cap on a Sr300 if I tweaked the steering fast enough no matter which ESC I used. Dsm2 receiver with same servo and esc=no brownout. I Still run a cap though on every vehicle. Sold off my Sr300 rx collection.
vfrninja is offline
Old 01-24-2013 | 06:27 AM
  #27733
Default Servo horn Savox?
Do the Savox servos need a "special" servo horn? I have used the "standard issue" Savox servo horn but there appears to be a bit of an angle going from the servo to the ball cup. IOW, it's not perfectly straight.
Additionally I broke my first plastic servo horn yesterday. I realize aluminum may have prevented this, but, would that have put more stress on the servo and possibly ruining it.
Also, I'm running the Avid aluminum bellcrank. Don't know if that matters or not, but, point being the Avid bellcrank does away with the servo saver. *sigh*
Any input?
shagnat is offline
Old 01-24-2013 | 07:05 AM
  #27734
t0p_sh0tta's Avatar
They use regular Futaba (25T) horns.
I don't have any problems with my 1258. It lines up perfectly.
edit: Must have been an ugly crash, I've never ruined an AE horn.
t0p_sh0tta is offline
Old 01-24-2013 | 07:08 AM
  #27735
vfrninja's Avatar
Any input?
Savox uses 25t / futaba horn. Some use aluminum horns. I have had good luck with the standard AE plastic horns, haven't broke one yet. *knocks on wood.*
If your using a horn other than the ae ones just move your steering to full lock both ways by hand to make sure there is no binding or anything hitting.
vfrninja is offline
