RC10B4.1 FT/WC
Old 01-23-2013 | 04:05 PM
  #27706
Wildcat1971's Avatar
Originally Posted by Cridd
I agree those minute steps are aggrevating for myself. I like my LRP and being a newbie to RC, I could play with that 10 settings and 4 modes on the SXX and feel the changes and understand them. Having 100 different vairables is something that makes my mind go crazy to point of frustration. But some guys dig on 100 settings but I like to keep it simple. I agree with the true spec is RTR, everybody has 100% of the same parts just different set ups. But everybody likes to play with stuff and aftermarket needs. I think blinky is cool and mod, but just don't give me 100 different modes with 20 different settings otherwise I will go insane with....what if!?!?
I dunno only takes me a minute to setup the esc and motor. Viper actually has some really good presets for 13.5, 17.5 and mod. I guess to each their own.
Wildcat1971 is offline
Old 01-23-2013 | 04:11 PM
  #27707
Cridd's Avatar
Originally Posted by Hipeoples
does any one know how i should clean my b4.1 wc after running it in the snow and on the beach?
take it over to the trash can and drop it in then head to LHS and buy a new one, lol.
Just joking, take it all a part and put it all back together again, new bearings, sand is a killer.
Cridd is offline
Old 01-23-2013 | 04:15 PM
  #27708
Cridd's Avatar
Originally Posted by Waflet
Hideeho
Last layout was REALLY hard (think concrete) red clay & rather dusty (even just a few minutes after watering the track) & starting to break up in spots. Green dd's (or similar) were the go to tire. Current layout is much softer & little to no dust & usually damp. Barcodes in clay or ss (or similar) are the go to tire now.
This for an indoor track, & you mentioned no rain, so I'm guessing yours is out door. For out door with more dust & loam, goosebumps --> 3d's --> dd's as the track gets drier picks up a groove. I've run all 3 on the same day as track conditions changed during a summer day.
One day I wish to run three different tires....that will mean I know what I am going!!
Cridd is offline
Old 01-23-2013 | 04:18 PM
  #27709
Cridd's Avatar
Originally Posted by Wildcat1971
you can lead a horse to water, but you cant make him drink it.
that is funny stuff.
Cridd is offline
Old 01-23-2013 | 04:20 PM
  #27710
Cridd's Avatar
If it is a preset I am good with it, but i watched a youtube on Viper and got a little scared. If it says, 13.5 run this and maybe tweak a few things then I am good.
Cridd is offline
Old 01-23-2013 | 04:38 PM
  #27711
Originally Posted by TCCustoms
what cap did you use? i hear alot about the CC version
Mine's from Spektrum. It's all the LHS had.
Jeckler is offline
Old 01-23-2013 | 04:50 PM
  #27712
ryanpatrickgore's Avatar
The viper is so smooth and so easy to use. I love em.
+1 wildcat
ryanpatrickgore is offline
Old 01-23-2013 | 05:32 PM
  #27713
What is "blinky"?
kevinrc is offline
Old 01-23-2013 | 05:39 PM
  #27714
mashimarowu's Avatar
Originally Posted by kevinrc
What is "blinky"?
Blinky is when your ESC is blinking literally. Meaning no boost/timing is added via the ESC.
mashimarowu is offline
Old 01-23-2013 | 05:47 PM
  #27715
I just bought a used B4.1 RTR, and the seller kept the servo for use in another vehicle.
I'm looking for a servo with performance "good enough" for low-level racing and power draw low enough to use with the stock ESC/motor and Spektrum receiver. I need the third receiver channel for a transponder.
Would a HiTec HS225MG be a reasonable choice?
kevinrc is offline
Old 01-23-2013 | 05:52 PM
  #27716
Originally Posted by bilster44
A very safe bet for red clay outdoors would be either proline m4's or aka super soft's I would think...the tread pattern would be something to ask the locals though.
I'm glad you said that about the super soft compounds. I was really pondering if soft would be soft enough, especially in the early morning, and "maybe" a soft compound for the later afternoon rounds.
Tread pattern is something I just don't know anything about regarding racing on red clay (firm, but, slightly dusty).
shagnat is offline
Old 01-23-2013 | 05:54 PM
  #27717
The speed would be fine at the higher voltage, but, the torque is a little low for my taste, but, may be doable on a not-so-technical track.
shagnat is offline
Old 01-23-2013 | 05:57 PM
  #27718
Matt Trimmings's Avatar
you need to be looking for a standard sized servo, that one is too small for the car. try here:
http://www.amainhobbies.com/index.ph...tandard-Analog
Matt Trimmings is offline
Old 01-23-2013 | 06:10 PM
  #27719
Thank you for the quick replies.
Is a "technical" track one with a lot of turns, or sharp turns (or both)?
I notice the pointer to AMain was to analog servos. Is that for lower power draw?
kevinrc is offline
Old 01-23-2013 | 06:11 PM
  #27720
Thats for cheaper
