RC10B4.1 FT/WC
Old 01-22-2013 | 06:39 PM
  #27676
Originally Posted by ptjonesus
thinking about a servo...thinking savox. any feedback? something about $80 or under. thanks.
I have Savox servos in my B4.1 and SC10 FT. Never had a problem with either. Wound buy them again. Really fast!
atwell906 is offline
Old 01-22-2013 | 06:56 PM
  #27677
TCCustoms's Avatar
model # and do they glitch with spek gear?
TCCustoms is offline
Old 01-22-2013 | 07:02 PM
  #27678
Default running on the beach
does any one know how i should clean my b4.1 wc after running it in the snow and on the beach?
Hipeoples is offline
Old 01-22-2013 | 07:05 PM
  #27679
mashimarowu's Avatar
I run savox and you can get either the 1257 or 1258... one is just faster and the other has a little more torque. I personally prefer the speed. I have heard they might cause brown outs with spektrum gear but I don't record which as I do not use them. The only reason for that is because the BEC voltage isn't high enough to provide for both the RX and savox servo, so you can try using a glitch buster, or getting a BEC.
mashimarowu is offline
Old 01-22-2013 | 07:09 PM
  #27680
TCCustoms's Avatar
Ah, wondering with this being a lighter ride than my SCTE to where it might not glitch or hoping it was a different servo as i think alot of the SCTE guys run the 1258 and use Spek and it glitches
Old 01-22-2013 | 07:12 PM
  #27681
sneako's Avatar
Pull the electronics. Break down the chassis, completely dry it (compressed air helps), use a soft tooth brush or paint brush for the sand stuck in all the crevices, clean and lube the bearings, and put it back together.
Sand and water can do damage if you don't thoroughly clean your kit.
sneako is offline
Old 01-22-2013 | 07:43 PM
  #27682
Well even though this is a lighter ride it doesn't affect your electronics... If you have a spek then just look for another servo or research about the spek receivers and which you can use.
Old 01-22-2013 | 09:04 PM
  #27683
Default Tires for Clay w/dust??
I'm running a 2wd B4.1 w/13.5t motor, no boost, timing +10.
Up coming race on red clay, very technical track. Relatively smooth, but, definitely a few rough spots. This track always has some dust (corn silk) on the surface.
So what tires would you guys recommend? Temps should be ~50*F and moderate humidity. Rain is not expected, but, who knows, right?
Thanks in advance for any help.
shagnat is offline
Old 01-22-2013 | 09:19 PM
  #27684
Check with the regulars, the faster regulars... Every track is so different especially dirt types. You can get a good idea just walking the pits.
associatevalley is offline
Old 01-22-2013 | 09:36 PM
  #27685
If I could do that I definitely would. This will be my first time at this track, and I just don't know who may be there. I'm fairly new to racing, just been bashing for a couple of years..... and I know my bashing tires.
Just no knowledge of red clay outdoor racing tires.
shagnat is offline
Old 01-22-2013 | 10:03 PM
  #27686
Gotchya. In your case I'd bring any small pin tires and anything remotly close to a rebar / suburb type tire. I'd also bring about $40 to buy a set and tools to glue them up before racing. RC racers are always happy to share setups, you'll have no trouble figuring it out quickly. I have no clue on red clay as I live in the desert. Hopefully someone can get you a little closer on here before you go. Good luck
Old 01-22-2013 | 10:10 PM
  #27687
LOL... I wouldn't know what to race in sand except for "sand paws" which wouldn't be a very good race tire IMO.
I've made a post on the race thread and maybe someone will chime in and if I'm really lucky my LHS wil have some in stock..... now that'd be too good to be true!....
shagnat is offline
Old 01-22-2013 | 10:39 PM
  #27688
corn_bread's Avatar
I run a savox servo sc-1251 http://www.savoxusa.com/Savox_SC1251...avsc1251mg.htm
and spectrum receiver and no brown outs. using orion r10 pro speed controller with a 17.5 motor
corn_bread is offline
Old 01-22-2013 | 10:43 PM
  #27689
I would prefer to pay that few extra dollars to get the 1257/1258 for faster speeds and a little more torque... Just my 2 cents :P
Old 01-22-2013 | 10:52 PM
  #27690
corn_bread's Avatar
I was going to as well then drove a friends with this one and it was plenty fast. I even turn down the expo when the track gets loose to prevent pushing.
I was surprised but then again the orion BEC is at 6v.
I have the 1258 in my 1/8 scale xray e-buggy and love it as well. but have to run a cap with those on my 1/8 scale, never tried on 1/10 scale
cant go wrong either way. just I know no brown outs with the 1251. both are 4096 digital so the resolution is great
