Like Tree5Likes
SC10 4x4 Thread
Old 01-17-2013 | 04:42 PM
  #32236
So heres what I got in the mail today. I will install it tonite and race it tomorrow night any advice? I will be using the 12mm ballstuds on inside tower and debating where to put ballstud inside middle or outside on exotek hubs.
AE SC10 4X4 is offline
Old 01-17-2013 | 08:29 PM
  #32237
tom2tone's Avatar
If you want to run stock roll center you will need 3mm of shims on the inner ball studs. It tells you with the instructions but I didn't have any shims and needed to order some. I just installed the outer ballstuds in the middle. Seems to work well. If you want to run the 8mm mod... read posts 365 to 367.
http://www.rcshortcourse.com/forum/t...10-4x4-19.html
tom2tone is offline
Old 01-18-2013 | 02:52 AM
  #32238
???E-Racer's Avatar
Default Gearing
I plan on running 32 pitch gears with the truck for durability.
If I go with a medium speed copperhead how would I gear it?
Also are the RPM upgrades any good?
???E-Racer is offline
Old 01-18-2013 | 10:12 AM
  #32239
Wild Cherry's Avatar
The Exotech hubs sure look nice ...
do they have same toe as the stock hubs ( 3 degree) ?
Wild Cherry is offline
Old 01-18-2013 | 12:10 PM
  #32240
wouldn't that be 0 degree... all toe in is in the arms/suspension mounts stock.
Sofa King is offline
Old 01-18-2013 | 12:14 PM
  #32241
Yup , meant the total toe = 3 degree
Thought the Exotech is a .5 , is that correct ?
Old 01-19-2013 | 06:09 AM
  #32242
The Exotek rear hubs are 0* STRC offers 0* or .5*
rippen is offline
Old 01-19-2013 | 06:57 AM
  #32243
Almost $100 for a set of Acer bearings. Do they sell them separately? Do anyone have promo codes for towerhobbies?
coconut is offline
Old 01-19-2013 | 08:41 AM
  #32244
drolmaeye's Avatar
You must mean for a complete set of ceramic bearings? You can get a complete set of steel (or carbide?) bearings for the SC10 4x4 from Avid for $26. It's a mix of steel, rubber, and revolution (one side steel one side rubber) sides.
Avid also sells bearings individually, so you can customize your set (e.g. regular bearings for light duty steering rack and ceramic for tranny and/or drive shafts). I'm on a bit of a budget so I've only ever used the $1/piece regular bearings.
I don't have Tower Promo Codes, but if you search thread titles, I'm almost certain you can find a thread with them. I think you need to be registered or a member with Tower to take advantage (not sure, never shopped with Tower). Good Luck.
drolmaeye is offline
Old 01-19-2013 | 08:52 AM
  #32245
Thanks, yes they are the ceramics.
coconut is offline
Old 01-19-2013 | 11:32 AM
  #32246
TY Rippen I tried to looked up the part on their site and could not find the info ..
Old 01-19-2013 | 01:22 PM
  #32247
Cain's Avatar
Originally Posted by shushamen
sofa you left me thinking about it, and it is true, I need like 25 mins to get to the transmission. duhhhhhhhh I can believed.....
Cain: unfortunately I thing I will need a new front top shaft, I tried to fix it but after a little while the gear just get free again.
yeah, that sucks when that happened, maybe they had a bad batch get out there or something.
Originally Posted by Eroomchris
I just purchased a sc10 4x4 it came with a tekin redline sc4x 4.5t and no esc. What esc would work best with this motor and will not break the bank.
As mentioned, a Speed Passion GT2.0 Pro works well, Reventon Pro works well too. HOWEVER, it will not work with 4 pole motors according to SP (The Reventon). Buddy of mine has it on his SC10 4x4 with that same motor, runs very cool, like 95 degrees on the ESC.
Hope all has been going well with everyone and their sc10 4x4s.
Cain is offline
Old 01-19-2013 | 04:25 PM
  #32248
Finally hit my first race today. Learning experience. Haha. 23 drivers I think. Finished 6 in b main so not last. I am good with that. It is tough. Did make a main in 2 wheel drive with 22 drivers. 7th. So work to do on the 4 wheel. Lots to learn about setup but I have found that its easier to learn at the track. Thanks to all of you who helped me get setup for my first race when I had no clue what to do at all.
hunter77 is offline
Old 01-19-2013 | 05:03 PM
  #32249
Cain's Avatar
Congrats. Keep it up!
Cain is offline
Old 01-19-2013 | 07:49 PM
  #32250
Looks to me like you had a fun day of racing, congrats.
rippen is offline
