RC10B4.1 FT/WC
Old 01-07-2013 | 01:44 PM
  #26971
Cain's Avatar
Originally Posted by tony montana
Cain, what did u use to space the shock? Also you had to file the towers correct?
the buggy came pre-spaced lol. Looks like just some standard AE blue spacers. By filing the towers you mean to clear the shock cap? from what I can tell on the rear, no, it wasn't filed. I'll give it another look and check but I don't recall.
Be careful about mounting the c hub on the back. For me anyway, it seemed like it really loosened up the rear a lot. Since you are on carpet, you might actually like that. But for me it was very hard to drive. I think Losi , kysho and a few others have vertical studs on the hubs and some of the settings change the front to back angle of the camber link. Because this is a tuning option they use, I would imagine that it does make a change. Plus I can greatly feel it. I plan to move the rear shock tower forward. The only side effect I can see it that it will move some weight forward. Will that be good or bad? I will find out :-)
Thanks for the heads up. That actually would be a good thing on carpet I am thinking, so who knows, maybe a side benefit. I may give it a try back the stock way and see how it goes. And if I need to lock in the rear more, may try more toe.
Cain is offline
Old 01-07-2013 | 05:12 PM
  #26972
Wild Cherry's Avatar
Weird , I use the C-hub ...
Made for more grip & less chassis roll for me .....
Wild Cherry is offline
Old 01-07-2013 | 05:14 PM
  #26973
Wildcat1971's Avatar
Tech Prophet
did you mount yours behind the hub?
Wildcat1971 is offline
Old 01-07-2013 | 05:18 PM
  #26974
YankeeFan123's Avatar
I do
YankeeFan123 is offline
  #26975
B.A. Racer's Avatar
Exactly. If people on here would just stop arguing about it, and just test it themselves. If they would test them back to back, they will notice a difference for sure.
B.A. Racer is offline
Old 01-07-2013 | 05:19 PM
  #26976
But they don't..which would solve half the questions
Old 01-07-2013 | 05:21 PM
  #26977
Tech Prophet
did you notice if it was looser when mounted front vs back? to me it was looser in the rear with the c hub behind.
Old 01-07-2013 | 05:41 PM
  #26978
There was not enough difference for me to notice. I consider myself a decent driver. I usually podium in sportsman or sometimes even win. When I run with sponsored guys I'm usually toward the middle/back, but a lot of good guys go to WC. So I figure some top guys would notice a difference but I don't. Then again, I run on high traction
Old 01-07-2013 | 06:11 PM
  #26979
[QUOTE=B.A. Racer;11646024]Exactly. If people on here would just stop arguing about it, and just test it themselves. If they would test them back to back, they will notice a difference for sure.[
Can't argue...
Just do your best to help the ones who don't understand.
Old 01-07-2013 | 06:42 PM
  #26980
Originally Posted by IndyHobbies.com
Thanks for the suggestions guys. In our buggy class, we have a mix of new drivers and more experienced drivers. So, it can be a cluster at times... Last night we were short on entries, so they put the stadium trucks in with the buggies and just called it "2WD class" so it was worse.
Don't know that it would help but sort of on topic....... Sc10 motor guard has a extra little plastic on it, makes a great handle.
associatevalley is offline
Old 01-07-2013 | 07:16 PM
  #26981
Tested it back to back many times and the important thing that guys haven't grasped yet is that we are all over the world and all run on totally different tracks. Each change you make can feel totally different on those different tracks.
For the tracks I run on and on my car, A hub tower gave more consistent bite through the turn but not the drive off the corner. C tower had the car rotate through the turn in more of a controlled slide but really square up and go when you grabbed the throttle.
Personally I like the C better but some guys like A. I am pretty sure Hartson has quite a few setups listed where he is on A and we have a few local guys here in PA/NJ/MD area that are faster with A too.
One thing I haven't tried was running the C with 2 washers (std Ubrace) just to see how it felt. All last winter I did 0 washers. This year I have been running 1. I'll probably try 2 soon just to see how the car feels different.
And for gods sakes, don't start throwing roll centers at me. I know what it does, but I don't care LOL. I just care about how the car feels after the change
Bob Barry is offline
Old 01-07-2013 | 07:24 PM
  #26982
Venom1836's Avatar
Well, since i need more traction exiting corners, should I add more or less washers on the u brace?
Also, this white plastic piece cracked, the motor still operates fine, but should I replace it?
http://www.amainhobbies.com/product_...-Insulator-Set
Venom1836 is offline
Old 01-07-2013 | 07:33 PM
  #26983
First, if it's broke, fix it.
Second, grasp the concept of what I just said.... Try both with the washers. Unless you are qualifying for Ifmar worlds, you have races that you can use to try things. You can ask us and we can all give you an answer and honestly, they can all be both right and wrong.
Do yourself a favor and get a note pad and just jot down this kind of stuff so you know. We can't all be named Ryan or Jarred
Old 01-07-2013 | 07:38 PM
  #26984
2canSAM's Avatar
This is some of the best advice. Run 5 laps, make 1 change and run 5 more. Make notes on lap times and what feels better. If it feels worse or lap times are slower change it back and run 5 more. I started Cavalieri indoor clay setup andchanges from there.
2canSAM is offline
Old 01-07-2013 | 07:40 PM
  #26985
Originally Posted by 2canSAM
This is sone of the best advice. Run 5 laps, make 1 change and run 5 more. Make notes on lap times and what feels better. If it feels worse or lap times are slower change it back and run 5 more. I started with Cavalieri indoor clay setup and made changes from there.
and I'm not really trying to be a dick about it. I mean the truth is I can tell you exactly what I would do to make your car work for me on my track but that's not going to help you...
Plus I am a much better mechanic than I have ever been driver...... I can set them up and get you right but I can't get clean runs to save my life LOL Need more practice!
