NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 12-02-2012 | 06:45 AM
  #10246
TCCustoms's Avatar
ok, kool...thanks ByteStream
TCCustoms is offline
Old 12-02-2012 | 08:20 AM
  #10247
Originally Posted by ta04evah
Correct me if I am wrong, when setting up the 1S esc you have a 2S plugged into it until all the settings are done?
Cheers
Rob.
I believe there was a time that such was the case for a certain circumstance; but, I have never had to do it on my HW 1S ESCs.
Bill
Still Bill is offline
Old 12-02-2012 | 09:08 PM
  #10248
COBRARACING's Avatar
Bill
120 amp original 1s esc there is no need to pug in a 2s for it to function with the lcd box for you to make changes but if you do need to do that then your dc -dc booster c is damaged. The none 1s version which you cut the red wire and run a rx pack for the use of 1s yes you do need to run a 2s lipo as this speed controller is not designed specifically to run 1s but can do so by running a external booster or rx pack which will power your receiver for your servo but will not power your esc as this function is plugged directly into your receiver and not your esc .
I hope this explains it better for you
COBRARACING is offline
Old 12-03-2012 | 02:32 AM
  #10249
I did some testing with stock firmware and eventually I began with turbo and boost to 0, should be a kind of no timing, right? I did not mind how it was because the car was quieter, next time I would try to turn it up a bit. The values ​​that I set before was 20 for and 24 for the turbo boost, advice?
the engine is a Lipotech 10.5t, RDF 6.22 ( hot bodies tcx with pinion and crown module 48 )
thanks for help.
puma303 is offline
Old 12-03-2012 | 04:51 PM
  #10250
TCCustoms's Avatar
hey guys...any help would be great! just got my Xtreme stock ESC in the mail and saw this in the pics but didnt think about it, is it a cap or BEC and how do i install it, just add it to the POS and NEG wires off the esc when i solder up the battery wires and thats it?
I kno what the wiring is, just not the cap/bec is...im assuming a cap but is it needed with my REVTECH 17.5 motor?
Old 12-03-2012 | 04:52 PM
  #10251
TCCustoms's Avatar
EDIT: Double Post
Old 12-03-2012 | 05:34 PM
  #10252
lewis110's Avatar
It's a cap, just solder it onto the positive and negative terminals
lewis110 is offline
Old 12-03-2012 | 06:27 PM
  #10253
TCCustoms's Avatar
ok, thanks...just got it all soldered up and about to hook it up to my laptop to reprogram to the blinky software
Old 12-03-2012 | 07:19 PM
  #10254
TCCustoms's Avatar
EDIT:
Got it all hooked up, added the cap and trimmed the body to have a hole where the fan blows and did the blinky software and the esc blinks an obvious red slow blink every 1-2 secs so i musta did something right, lol.
So when you hook this up to the program card you still use the ESC(middle receiver plug) on the LCD box? I know the SCT Pro uses that slot so that is why i used that slot and as soon as i turned on the esc it went to the options menu BUT all went good.
As far as gearing go's the buggy came stock with a 22t pinion so should i stick with that on the REVTECH for a tight indoor track or can i gear this thing up like my buddy said?
Old 12-03-2012 | 11:19 PM
  #10255
I'm having a problem with the stock firmware. If I set my BRAKE DRAG FORCE in custom (value 23) and then put INITIAL BRAKE § FORCE to =DRAG BRAKE FORCE I can't enter the reverse, putting on INITIAL BRAKE FORCE another value reversing enter and work correctly. I tried to flash several times, even several times in a row. Some help?
puma303 is offline
Old 12-04-2012 | 01:01 AM
  #10256
arn671's Avatar
Default Link for 2 in 1 software upgrade
Hey Guys, wondering if anyone has a link to download the latest software for both the ESC and the 2 in 1 programmer? Tried going to the HW site but the links on there are not working? the links I was able to download are different visually from the ones shown in the manual. I plug the ESC into the programmer and it says to upgrade the software which has already been done. Thanks for the help
arn671 is offline
Old 12-04-2012 | 06:28 AM
  #10257
lewis110's Avatar
http://www.hobbywing.com/product_show.asp?id=218
That's the link to the V3.1 software, that's the news program. After you download it to your computer, you need to unzip the file, I use jzip. Then you can download it successfully. 930stock/mod are the newest firmwares for a 2.0/2.1 esc.
lewis110 is offline
Old 12-04-2012 | 06:51 AM
  #10258
ByteStream's Avatar
Post #10225
ByteStream is offline
Old 12-04-2012 | 10:13 AM
  #10259
TCCustoms's Avatar
I just noticed the zero timing i installed on the esc is V3-508...so if it pops up on the drop down menu, i can use it on the ESC?
Old 12-04-2012 | 10:52 AM
  #10260
ByteStream's Avatar
Your question has alredy been answered.
Reread Post #10225
