The Speed Passion Thread >
Like Tree57Likes
Old 11-29-2012 | 02:39 AM
  #10786
Hello,
How many internal timing degrees have each motors?
1C105V3 Competition V3.0 1 Cell Motor - 10.5R
138105V3 Competition V3.0 Brushless Motor - 10.5R
SP000037 1/10 Competition MMM series 10.5R Brushless Motor
Regards,
JoseLu
ysyracing is offline
Old 11-29-2012 | 07:20 AM
  #10787
Originally Posted by ysyracing
Hello,
Regards,
JoseLu
Out of the box the V3.0 and V3.0 1 cell have 0 to 10 degrees of timing available and the MMM has 10 to 20 degrees. Any will support from 0 to 50 by replacing the timing board with the appropriate one (which covers 0 to 10, 10 to 20, 20 to 30, 30 to 40 and 40 to 50 in the 5 different boards available.)
linkless is offline
Old 11-29-2012 | 07:28 AM
  #10788
Cain's Avatar
timing boards on sale right now like everything else, not a bad time to get some.
Cain is offline
Old 11-29-2012 | 09:24 AM
  #10789
Hello,
Regards,
JoseLu
Hello, thanks for your reply.
Are you sure?
I think that the 0º external timing corresponds to 12º of internal timing, but I am not sure.
Regards,
JoseLu
Old 11-29-2012 | 10:28 AM
  #10790
rimracker's Avatar
Originally Posted by joech
Does the GT2 has DDRS in blinky mode?
Thanks.
I know the GT 2.1 prostock does.
rimracker is offline
Old 11-29-2012 | 10:39 AM
  #10791
Cain's Avatar
Gt2.0 Pro does too
Cain is offline
Old 11-29-2012 | 07:35 PM
  #10792
skypilot's Avatar
Are you sure?
Regards,
JoseLu
I believe you are correct, or at least that is what I was told also.
I know that the old SP motors that didn't have adjustable timing had 12 or 13* degrees built in timing,
skypilot is offline
Old 11-30-2012 | 12:57 AM
  #10793
yes, with the stock board the V3's are adjustable between 0 to 10 degree, use option board to adjust it up to 50 degree.
gpm-parts.com is offline
Old 11-30-2012 | 10:15 AM
  #10794
Originally Posted by Akita
Which is the fastest FW for the PRO with 5.5R SP ?
Everyone play with 4.5 boost , its a big track .
I have istall the latest stock with all max .
The mod is better ? Can i use hybrid boost at mod ?
Stock1 (boost/turbo) with 4.5....we have setup on our website for you to try. Use it...that is the fastest setup so far.
Solara is offline
Old 11-30-2012 | 10:17 AM
  #10795
Originally Posted by skypilot
Thanks thats the info I was looking for. I thought there was a software for boost in mod. Or was that for the GT 2.0? Thanks again.
GT2 had a boost for mod software but it was a watered down version of boost...because we were worry about running boost with mod motor, if not handling correct, it will have a lot of burning motor....but after all these time of testing and running with the boost/stock version with MOD motor...everyone get a grib on it and no one run the boost mod version no more...
For Reventon, we just don't bother to make the boost mod version...everything for boost will be using STOCK1.
Solara is offline
  #10796
Thanks.
Yes....on GT2.
Solara is offline
Old 11-30-2012 | 10:19 AM
  #10797
Hello,
Regards,
JoseLu
I think your question should be asking about the BUILT IN TIMING from these motor...all of the SP motor are running abotu 12-15* built in timing...plus the sensor board timing goes from 0-50. Plus your ESC software if you are running timing software.
Solara is offline
Old 11-30-2012 | 05:54 PM
  #10798
GT 2.0 pro question: Could a GT 2.0 Pro handle a 4 pole 4000kv motor of would I see a nice fire???
bigwavedave33 is offline
Old 11-30-2012 | 06:06 PM
  #10799
Cain's Avatar
Yes. That is the motor I use right now in an SC10 4x4 with that ESC.
Cain is offline
Old 11-30-2012 | 06:23 PM
  #10800
What about in a heavier 4x4? SC10 is pretty light comparably to the SCTE I guess I should have mentioned chassis and weight? I thought it would be ok though.
