NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 11-24-2012 | 07:59 AM
  #10186
Pro10noob's Avatar
So at this moment the weak brakes are caused by the software??
As what i have read with the old software all is ok but when upgrading to the new software the brakes as crap so to say.
Why not use the brake software from the old versions and the rest from the new software?
Win win situation?
regards Roy
Pro10noob is offline
Old 11-24-2012 | 08:09 AM
  #10187
2wdrive's Avatar
Maybe it is asked already but what happens when you put turbo and boost on zero in 930 software? no brakes as well?
2wdrive is offline
Old 11-24-2012 | 08:32 AM
  #10188
AdrianM's Avatar
I cannot run 508 v3 on my new Justock. I keep getting a upgrade software popup.
I am running 1.08 on my LCD box. 1.11 is not supposed to work on ESC's other than the V3.
AdrianM is offline
Old 11-24-2012 | 03:58 PM
  #10189
COBRARACING's Avatar
Adrian please send me an email at teamcobraracing @gmail.com
I will help you out
COBRARACING is offline
Old 11-24-2012 | 04:57 PM
  #10190
Lets all get together and wish Hobbywings Head Designer and One of the company directors Michael Lui a Happy 29TH birthday .
Old 11-24-2012 | 04:59 PM
  #10191
RL.2002's Avatar
happy birthday michael
RL.2002 is offline
Old 11-24-2012 | 06:54 PM
  #10192
ta04evah's Avatar
Happy birthday and good fortune Michael.
Ok, in regards to the braking issue with the blinky software, it has been explained in detail here before, but I'll go over it once again in case it was overlooked.
The best way to explain the problem is to have the car sitting on a car stand on your table.
* Firstly set the esc into blinky mode 508 no timing.
* Re calibrate the esc to your transmitter settings.
* Set drag brake to Zero
* Hold full throttle and then go to full brakes and note how long it takes for the motor to stop.
* Now, this next step is to first do the same by going to full throttle but instead of going to full brakes, pause *very briefly* in neutral and then apply full brakes.
There will be a very noticeable difference in how fast the motor will stop when you release the throttle and pause briefly in neutral before applying full brakes, as opposed to going from full throttle to full brakes.
This effect/issue will be even more noticeable with lower wind motors, but can also be noticed with higher winds including 21.5 motors.
I agree with Shawn68z, HW makes great esc's and are great value. Even with the blinky brakes issue I'll be sticking with HW, as there's no other brands that give the smooth feeling of a HW and are reliable.
Cheers
Rob.
ta04evah is offline
Old 11-25-2012 | 11:49 AM
  #10193
Default HW JustStock question
Is the fan needed with the JustStock Club ESC? (for use in F1 / 21.5)
Thanks in advance!
madjack is offline
Old 11-25-2012 | 01:24 PM
  #10194
TCCustoms's Avatar
for the price i would advise you to always use a fan...they are 5-10 bux, thats cheap insurance if you ask me
TCCustoms is offline
Old 11-25-2012 | 01:59 PM
  #10195
pmc
Hello
Today i have tested the software 526 in the V3 in indoor carpet track.
I don't have any issue with the brakes , if i set to much brakes in the esc they lock the wells of the car.
Good work Angelo, keep the good work and costumers support.
Best regards:
Pedro Silva
pmc is offline
Old 11-25-2012 | 05:04 PM
  #10196
lewis110's Avatar
Thanks in advance!
On my Xtreme stock in blinky mode using a epic D3. After a 4 minute race my esc was coming off the track at 80* F. That was with no fan. I would say you wouldn't need it with a 21.5, run a few minutes then temp just to make sure.
If I was running a 13.5 or 10.5 with a bunch of boost/turbo then yes I would say use the fan. But I think your safe without it.
Roger
lewis110 is offline
Old 11-25-2012 | 05:11 PM
  #10197
lewis110's Avatar
I will help you out
I gotta thank Angelo for the great customer service he gives at Hobbywing. Over the last week I've had a problem with a new combo I put in my mini late model and needed some help installing the new files into my computer program. Each email was answered within a few hours.
If you guys need help and can't find the answer here feel free to send him an email teamcobraracing @gmail.com his customer service really is second to none.
Roger
lewis110 is offline
Old 11-25-2012 | 05:30 PM
  #10198
rcuser67898578 is offline
Old 11-25-2012 | 09:31 PM
  #10199
ta04evah's Avatar
Originally Posted by Johnny-RC
Angelo I'm not talking about the V3 esc..... the blinky firmware in the V2.1 and older esc's i.e. V2_508 vs. V3_508 the brakes are noticeably less. And I have done all the tricks, 100% reverse force helped slightly. Radio is set correctly. The brakes even sound different when applied then they did with the V2 firmware. Also I have tried to get back to the V2 firmware but the software wont let me.
+1 Also talking about the v2.1 & Xtremestock esc's in regards to soft brakes in blinky (no timing) mode.
Have tried numerous things including but not limited to:
Set reverse force to 100% (even though the esc is set to fwd/brk only), which like above helped slightly.
Set my throttle to reverse an my transmitter & re calibrated the esc.
Set braking force to 100%
Tried varying amounts of drag brake.
Set intial brake to 20% (another suggestion from a forum member in this thread).
Apart from the first mentioned suggestion, nothing else done anything to improve the soft braking issue.
Maybe I should make a video to show the issue more clearly?
Cheers
Rob.
ta04evah is offline
Old 11-25-2012 | 10:03 PM
  #10200
Thanks in advance!
Always run a fan electronics the cooler they run the more efficient they are = more performance
