Like Tree5Likes
SC10 4x4 Thread
Old 11-11-2012 | 04:41 PM
  #31111
Maddog94's Avatar
fq06
Looks like I will certainly be investing in the RCshox 2 stage pistons, but if they are that good, why would I not want to run them indoor as well as outdoor? Is there some drawback to their use on smooth surfaces?
Maddog94 is offline
Old 11-11-2012 | 04:51 PM
  #31112
Acill's Avatar
Originally Posted by Cain
I would suggest starting with RC Shox starting setup as a base point and go from there for outdoor, but using the M2C blocks in the 3.5 degree setting.
As for having the power, if your motor is not getting hot, I would say gear up or you can play with some timing. I found using a little as 5 degrees of timing in say a turbo fashion (ie- after a certain RPM range) really woke up my Tekin Pro4 4000Kv motor.
Or, you can go with something with a higher Kv. It may be that the competition is just using really powerful motors at your track.
by the way, how would you describe the conditions you run on?
Well SRS is well groomed hard pack with a bit of fluff, sticky when wet, loose when dry. Glitch is hard packed and loose on top. Not quite a loamy track but it does have some lose dirt on top of the hard pack at times.
The hacker 4 pole I have is the newest one. Its a 450 5.5 can. I also have a Tekin SC4X 4.5 I can put back in. What ESC settings in the RX8 do you recommend? I hate being suck a great driver indoor and then look like crap outdoor. Its not my lines, its just the speeds.
Acill is offline
Old 11-11-2012 | 06:03 PM
  #31113
sugs's Avatar
Originally Posted by Acill
When I go on an outdoor track I feel so much slower, even on a similar sized track. I dont know if its just me feeling like I am or if I really am, but I have trouble keeping up so I dont do well. Any ideas on what would speed me up on an outdoor track? Whats good gearing for outdoors? Should I use the optional front overdrive gear? Order a different sized spur?
Is your truck squirrelly outdoors? I don't run outdoors very much but when I do I step down in spring rate going to blue fronts in front and white fronts in rear. I also go up 1-2mm in ride height as well. I remember it being pretty good then but it has been a while.
sugs is offline
Old 11-11-2012 | 07:27 PM
  #31114
tom2tone's Avatar
Guys.. I got a question. My steering link keeps popping off the ballstud. It took me out of a qualifier last week and put me way back in the main. Then it happened 2 more times today. I replaced both the ballstud and the ball cup links. What can I do to fix it? Is there a way to put captured set-up like the rc8's have?
tom2tone is offline
Old 11-11-2012 | 08:40 PM
  #31115
njnewc's Avatar
Gents are u running the emulsion or bladder setup in ur shocks. Also what springs and shock weights r u using. I have checked the pro setup sheets but I want to see what u guys r running. Thanks
njnewc is offline
Old 11-11-2012 | 09:32 PM
  #31116
Wild Cherry's Avatar
for indoor clay
use the emulsion shock
Ft
yellow spring
1.2 piston
32.5W Ae oil
yellow sway bar
Rear
yellow spring
1.2 piston
30W Ae oil
blue sway bar
Wild Cherry is offline
Old 11-11-2012 | 10:00 PM
  #31117
fq06's Avatar
Originally Posted by Maddog94
fq06
Some people that run them will switch to standard piston (less active, more of a muted feel) indoor but I ran them indoor & outdoor.
You will feel more of their advantage outdoor though where they really shine.
fq06 is offline
Old 11-11-2012 | 10:17 PM
  #31118
iterator's Avatar
N/w Shoot-Out Race report
This event is a one day race series that tours the N/w's indoor tracks ...
BRCR@ B-Town - TRCR @ Tacoma
4-Season @Lacy -TOP GEAR Hobby @ Portland
Race program is 2 qualifier's & 2 main's for the A .
2 bump ups from the lower mains...
Ae Sc10 4x4 Tq's & wins >Mike Brown
Ae Sc 10 4x4 earns 2nd place >Chris Gould ..
Came in 6th > Wild
We used the VTS slipper from Ae ......
about 110 entries
2 heats of Sc 4x4, 8 car each
Some footage with Cherry, Brown, and Gould throwing it down in their SC10 4x4s, even if you don't watch the whole race it is worth it to watch the finish
+ YouTube Video
iterator is offline
Old 11-11-2012 | 10:40 PM
  #31119
Originally Posted by TXRC8racer
Ran the Exotek front locker last night at Mikes Hobby Shop in Carrolton Tx. In practice the truck pushed way to bad, and after a couple of practice sessions I did not like it at all. So I went back to old setup. Plan on playing with the locker more at Monday night practice.
dunno what your set up is, but try the clicker clicking and/or lower your front diff weight a bit? also stiffer front springs in the back? I love the pull out of the turns, but i had to make the front soft and rear stiff to get it to rotate.
maddysdaddy is offline
Old 11-12-2012 | 08:05 AM
  #31120
Cain's Avatar
Unfortunately I don't run the RX8. You may want to see what setups are out there for the ESC and motor in 4x4 SCT. Personally, from what I saw from speed passions direction I was starting my boosting at around 3000K RPM with say 5 degrees to start with. That may give you a starting point with the RX8. The Speed Passion guys were boostering there 550 2 Poles motor A LOT in comparison to the 540 4 Pole ones which don't like it.
You are running a 5.5 motor, 540 can I believe you mean which is like 4000Kv? It will definitely be slower than a 4.5 can motor on the top end. I personally couldn't get enough speed in comparison to the 540 Pro4 4600Kv guy when gearing up as the motor would get into heat ranges I didn't like. But, when I did turbo like I mentioned and dropped my pinion size, I was able to be right there speed wise with him and temps went down significantly.
As for setup if you feel everything feels good your all set then. But if you have time, I would be curious to see how your current setup compares to RC Shox new starting setup which uses the lighter White front spring in the rear now than the blue to start from what I recall Marcus telling me.
That spring setting I believe is what Marcus now recommends, at least the whites in the rear. For the stuff I ran on out here when it was outdoor season, I was running Blues fronts and I think Green rears and it worked really well. Still gave me the suspension action I needed that the stock rear yellows didn't but had the grip I needed too. The M2C block though really locks in the rear end so it won't be squirrely.
Cain is offline
Old 11-12-2012 | 03:44 PM
  #31121
fq06's Avatar
For the RX8, I run current limit @ 100 indoor and anywhere from 90 down to 75 outdoor.
That limits power sent to the motor for the first certain amount of rpm (not sure what that value is, maybe first 20%?) on the bottom end then goes to 100% power. Good in less than ideal traction situations like dry hard pack with a little loose dirt on top.
Timing for a 4 pole is zero. Two pole, time as temps allow.
4 pole FTW.
Push is set to 20. That keeps a hair of throttle on when you go to neutral so you roll through turns a little better... better flow for me. Go to any amount of brake and push is inactive.
Zero drag, preference like the push setting.
The rest like neutral width, min throttle- brake, brake strength and so on can be copied off the pro setups on the tekin site.
Make sure you're running the 2.23 firmware, there is a sc4-x specific pro sheet if you want to go back to the tekin and a couple 4 pole sheets (pro4) for your hacker.
http://www.teamtekin.com/hotwire/ESC...up-sheets.html
fq06 is offline
Old 11-12-2012 | 04:45 PM
  #31122
tom2tone's Avatar
Anyone? Sorry to be a pest but if I need to order anything, I'd like to do it asap as I am racing again this sunday.
thanks
tom2tone is offline
Old 11-12-2012 | 06:33 PM
  #31123
fq06's Avatar
Never had any issues with any of the links popping off any of the ball studs, sorry. Stock is all I know of out there for the steering links anyway.
Maybe make go back to stock tension on the servo saver?
fq06 is offline
Old 11-12-2012 | 07:10 PM
  #31124
tom2tone's Avatar
Yea, I never had this issue until I put the optional steering rack on. Maybe I'll just go back to stock.
and also I'll check the tension and go from there.
tom2tone is offline
Old 11-12-2012 | 09:09 PM
  #31125
Default 2012 Spektrum Race - 4WD Mod SCT
Here is a pretty dialed SC10 4x4.....Team Associated's Mike Nelsons A-Main run at the 2012 Spektrum race.....race had over 320 entries.
+ YouTube Video
Jason Snyder is offline
