The AE FActory Team B44.2 Thread >
Old 11-08-2012 | 01:04 PM
  #526
hijinx's Avatar
Ah that sucks BIG time, I'm glad I allways use my lipo bags when ever I charger, shows you just don't know
hijinx is offline
Old 11-08-2012 | 02:49 PM
  #527
ryanpatrickgore's Avatar
It did stink bad,but we cranked on the fans they usto use for nitro races and cleared out pretty quick. I decided to leave tho it was gross after that.. Yea he kinda killed the fun, the chassis and the owners profits for the rest Of the day haha.
Be carefully guys. That's the third one I've seen this year
ryanpatrickgore is offline
Old 11-08-2012 | 08:24 PM
  #528
UN4RACING's Avatar
Originally Posted by rigor
Anyone else seem to have over tightness with the drive pinion gear once mounted in the transmission housing ? I have it in both front and rear trannys.
I have a 44.1 , so I'm pretty familiar with the platform. On my new build, if I put just the diff in with correct shims/bearings, it spins nice and free with no side play. But the damn drive pinion is also shimmed right, and its a bit tight with slight binding. Normally after I'd rebuild my diffs on my 44.1, when everything was back in the housing, it would spin nice and free.
EDIT: Found the issue, little bit of flashing on both drive pinions that was causing the pinion to not move as far up as needed. I haven't had to replace any gears in my 44.1 for a while now, so I forgot to check for this. Actually now that I look, the manual states to trim flashing from the drive pinion :P
Mine was the same darn way. If I laid it in the bottom of the tran case it rubbed but in the top it didn't. At any rate I will get some pics of the pinion deal up. But check out the vid. Mine is the black one. Mind you it was 35 weight oil on a dry track. It did pretty good. There was a 44 a yoke and another .2 in the mix. Practice night... Not bad for a first night out.
http://www.youtube.com/watch?feature...&v=OXwGPDOApHo
UN4RACING is offline
Old 11-08-2012 | 08:25 PM
  #529
keidel's Avatar
Default Front a arms
The front A arms have the same part # as the B44.1. I broke one tonight and put on a old one. Where is the difference just in strength or shape also. Any reason I should not run the old one till I replace it with a new one.
keidel is offline
Old 11-08-2012 | 08:34 PM
  #530
UN4RACING's Avatar
I'm sure the new ones are the new norm. That's why the part number matches. They have a gusset just to the chassis near the inner hinge pin.
Old 11-08-2012 | 09:27 PM
  #531
Thumbs up
ok fellas I tried everything to figure out this problem but i still cant receive a conclusion to this problem. I took my b4.1 shocks off and put them on the b44.2 and still had the stiffness of the shocks. here's some pics. I appreciate all the help. Also, my al. hub is hitting the inside of my rears wheels when the shocks are fully engaged.
Attached Thumbnails The AE FActory Team B44.2 Thread-photo-1.jpg   The AE FActory Team B44.2 Thread-photo-2.jpg
DJGray17 is offline
Old 11-08-2012 | 09:46 PM
  #532
Arigato's Avatar
The ball stud and camber link should be on the front side of the hub carrier.
Arigato is offline
Old 11-08-2012 | 09:52 PM
  #533
patiofurniture's Avatar
The ball of the ball studs on the top deck should be on the bottom of the top deck instead of the top, and your hubs are flip flopped left to right.
Once you get that fixed you should be good!
patiofurniture is offline
Old 11-08-2012 | 09:53 PM
  #534
cantrell8's Avatar
Your ballstud should be under your topdeck, the hubs are on backwards. Change that an see if the problem is still there
cantrell8 is offline
Old 11-08-2012 | 10:04 PM
  #535
yeah thats what I just did and it solved my problem. Thank you
DJGray17 is offline
Old 11-08-2012 | 10:53 PM
  #536
mini-t12's Avatar
I'm not going to lie, I've never seen anyone make that mistake before... but im glad you solved it
mini-t12 is offline
Old 11-09-2012 | 12:02 AM
  #537
JEDI BASS's Avatar
Default Glad I'm not the only one who screws up
I've found it's very easy to get stuff reversed or backwards. I just supervised my daughter's first kit-build (SX3) and we got her front yokes swapped (left on right and vice versa) and also had her rear eccentric hubs (which control belt tension) messed up... had the tension loose on one side and tight on the other. Thanks to the help of others here on rctech, we got it fixed before we ran the car. Nothing like messing things up to teach you how to get it right the next time.
JEDI BASS is offline
Old 11-09-2012 | 12:48 AM
  #538
rigor's Avatar
+1 Well said
rigor is offline
Old 11-09-2012 | 06:14 AM
  #539
UN4RACING's Avatar
+1 Well said
Here is a quick vid of the issue I mentioned on the pinion. I have seen fellas do a mod where they have drilled a hole for easier access. I am sure I could run it this way but I stripped a set screw once trying to get it centered with the spur.
http://s1221.beta.photobucket.com/us...24101.mp4.html
Old 11-09-2012 | 06:18 AM
  #540
UN4RACING's Avatar
Here is the new one. I have never broke one in this spot but they must have had a reason for changing it. I would like to see them make some with out the webbing myself.
