Kyosho v-one r4!!!! >
Kyosho v-one r4!!!!
Like Tree26Likes
Kyosho v-one r4!!!!
Old 10-19-2012 | 07:05 AM
  #766
kest's Avatar
Post
Originally Posted by GREGORY!
do you use aftermarket brake pulley??
No Greg..I mean not yet..for now I use all stock parts
kest is offline
Old 10-24-2012 | 08:13 PM
  #767
kest's Avatar
Post
Another mod following shimos SP version. I grind flat spot on the end of both center and main shafts and installed those pulleys in the opposite way ..and i also use the RRR shimo edition belt tensioner to complete the tranformation..
Attached Thumbnails Kyosho v-one r4!!!!-picture-008.jpg   Kyosho v-one r4!!!!-picture-007.jpg   Kyosho v-one r4!!!!-picture-006.jpg
kest is offline
Old 10-25-2012 | 05:25 AM
  #768
GREGORY!'s Avatar
nice job there man.if i find time and camera i will upload my mod in the rear bar mount.
i must do something with these heavy pulleys and shafts of this car!!!
GREGORY! is offline
Old 10-25-2012 | 09:04 AM
  #769
The R4 SP mounts the pulleys this way. So you can always get the SP shafts to do this modification if you don't feel like grinding the original R4 shafts. I also want to add that the carbon fiber on the SP is way way better than the junk they had for the original R4.
I'm also looking for a way to reduce the weight of the pulleys. I did replace both 18T pulleys with the Capricorn Kelvar pulleys from the 801. Not the biggest weight savings but it is something. I also put the Capricorn Kevlar front diff pulley from the C02 on as well.
Highside20 is offline
Old 10-25-2012 | 04:00 PM
  #770
GREGORY!'s Avatar
are the Kevlar ones stronger ?how their teeth hold?now about a real weight save i think that i must change to pin style pulleys.for the rear i think nt1 rear axle can fit.
GREGORY! is offline
Old 10-25-2012 | 07:48 PM
  #771
I'm not sure if they are any stronger. I just don't have enough time on them to tell yet. All I know is that they get dirty easier or just show it more.
I would also like to know if the NT1 axle would fit. Even if the Capricorn would fit. I do know the NT1 light weight brake pulley holder will not fit Kyosho pulleys and since the R4 runs a different tooth count, the NT1 pulley will not work either.
Old 10-29-2012 | 07:35 PM
  #772
Great Kelvar pulleys...
Can you upload some pictures?...
It was necesary to adjust something or just fit perfect like the original ones?...
TomasRC is offline
Old 11-01-2012 | 01:33 AM
  #773
kest's Avatar
Any pictures of yr car ? I'd like to c yr mod. tq
kest is offline
Old 11-09-2012 | 04:31 PM
  #774
GREGORY!'s Avatar
hey guys.has anyone tried to use the rrr evo 2 brake rotor-pulley?vz239.
GREGORY! is offline
Old 11-09-2012 | 07:04 PM
  #775
Default wow
i want one!!!
masterdiver808 is offline
Old 11-11-2012 | 07:53 AM
  #776
Shimo's R4 is looking good on track.
30Tooth is offline
Old 11-11-2012 | 07:59 AM
  #777
GREGORY!'s Avatar
yeah,but it has a lot more for the best time.
GREGORY! is offline
Old 11-11-2012 | 08:08 AM
  #778
Yeap totally true.But he's a good driver and I hope he makes the A main.
30Tooth is offline
Old 11-14-2012 | 06:08 PM
  #779
GREGORY!'s Avatar
hey guys.how much weight your r4 ready to race?
GREGORY! is offline
Old 12-03-2012 | 03:16 AM
  #780
GREGORY!'s Avatar
Hello guys.this is my car.
GREGORY! is offline
