Like Tree2Likes
Xray T4 '13
Old 10-18-2012 | 07:26 AM
  #781
Team EAM
Originally Posted by d.k.vmatt
That's for the t3 12 is the space about the same?
Sorry....I missunderstood your question the first time.
The T4 has more room for gearing with a larger adjustment on the motor it seems. I was able to run a 104 in stock blinky class. Which I couldnt do before.
EA
EAMotorsports is offline
Old 10-18-2012 | 07:31 AM
  #782
sweet thanks. Im having alot of trouble finding a 69t 48p spur
d.k.vmatt is offline
Old 10-18-2012 | 08:12 AM
  #783
I'm using the Kimbrough one in my T3. Should fit the T4 too..
http://kimbroughracingproducts.com/s...oduct_id=29810
halldor is offline
Old 10-18-2012 | 08:18 AM
  #784
What did you have to modify?
Sean B. is offline
Old 10-18-2012 | 09:37 AM
  #785
Robertcooper88's Avatar
Does anyone know when the T4 will be in the states? Seems like it is taking awhile but I am impatient.
Robertcooper88 is offline
Old 10-18-2012 | 09:40 AM
  #786
M-Technic's Avatar
Didn't you have yours two weeks ago dude?
M-Technic is offline
Old 10-18-2012 | 09:43 AM
  #787
that was mine. I was wondering when the rest were coming.
Old 10-18-2012 | 02:30 PM
  #788
whats a good CA for doing the chassis...i never owned a chassis like this before so it will be my first time sanding it etc.....
rescue119 is offline
Old 10-18-2012 | 02:51 PM
  #789
I always liked the green zap a gap for chassis. That was a while ago though. I need to get some so when the kits finally arrive some year, I'll be ready to go.
Maybe I should wait though. The glue might harden in the bottle before the kits arrive
Sean B. is offline
Old 10-18-2012 | 03:14 PM
  #790
morgoth's Avatar
I sand the edge with 400-600 grid sandpaper and then apply a layer of CA glue with a cotton swab. I soak it with CA and then apply it to the chassis. You'll have to use a few cotton swabs, because they harden after a 10-15 seconds because of the glue.
morgoth is offline
Old 10-18-2012 | 03:30 PM
  #791
An easier method for the chassis if you want a nice black matte finish on the edges is to use blue loctite. Wipe it on and then wipe off the excess.
or8ital is offline
Old 10-18-2012 | 03:38 PM
  #792
That would not seal the edges.
Sean B. is offline
Old 10-18-2012 | 04:24 PM
  #793
What us the reason to seal the edges of the carbon? I haven't done it to my Sakura top deck and its still perfectly fine.
Old 10-18-2012 | 04:31 PM
  #794
Not an issue.
or8ital is offline
Old 10-18-2012 | 04:35 PM
  #795
Sanding and sealing the edges helps prevent chassis delamination in a crash. It's not a 100% solution but it helps. At least that's what I've always been told (and read).
tcdrvr2 is offline
