Like Tree5Likes
SC10 4x4 Thread
Old 09-26-2012 | 06:32 AM
  #29896
fq06's Avatar
Originally Posted by CraigMBA
I learned a couple of things!
My Hudy setup station is the best thing ever. If you aren't using one, you have no idea how bad of a job you are doing using whatever camber gauge you are using
+1000
If I remember correctly we talked about using a setup station pages back. You had one but hadn't used it but you were going to give it a try. Looks like you used it and realized just how far off you used to be when it looked A OK to the naked eye or even a camber gauge.
Not using a proper setup station pretty much guarantees that you are off at least 0.5° on everything.
Enjoy your properly setup truck and how it handles
fq06 is offline
Old 09-26-2012 | 06:45 AM
  #29897
CraigMBA's Avatar
Originally Posted by fq06
+1000
I used an RPM camber gauge previously.
Off by half a degree?
CraigMBA is offline
Old 09-26-2012 | 06:47 AM
  #29898
fq06's Avatar
Yeah, I guess its not plus or minus 0.5°... it's 0.5°+
fq06 is offline
Old 09-26-2012 | 07:19 AM
  #29899
Those pins are hardened tool steel, they are the most durable part in the whole CVA (IMO). If that part is shot, I shudder to think what the rest of the CVA looks like.
The new CVA-bones are just 1-2 race-days old and the pins i made out of hardened steel nails broke at the end of the first race-day. The original AE-parts also broke, but just because the bones were that much worn out that there was a sharp edge.
How often do you replace your bones/pins/axles? Maybe the problem is not the CVD but another part of the car :S Too less slippery can't be the problem because i have the V1 slipper.
//EDIT: also the right bone was MUCH more worn out than the left, but the pins broke on both sides.
Cody227 is offline
Old 09-26-2012 | 07:22 AM
  #29900
fq06's Avatar
Running mine since October and they are still in great condition, pin and bone. Odd that people are having issues.
I would think that you have the shock down travel limited, but if not... is the arm traveling too far down allowing the bone to back out almost all the way from the outdrive getting that pin into the sharp edge of the outdrive?
Wait, that's up travel that's limited... never mind.
fq06 is offline
Old 09-26-2012 | 07:27 AM
  #29901
ryanpatrickgore's Avatar
Yea people were cuttin the tunnel to accommodate for tall Esc's that don't fit underneath it. If you run indoors and have a ft brace you really don't need a tunnel if there is no rocks or anything loose on top. We drive hard pack clay like asphalt almost, so there isn't really anything that could get in there.
Outdoors I would not try this tho.
ryanpatrickgore is offline
Old 09-26-2012 | 07:33 AM
  #29902
Can someone make a pic of a bone he drives since a long time? I used mine since about April 10 2012 They broke about 1-2 months ago.
Cody227 is offline
Old 09-26-2012 | 07:42 AM
  #29903
07Forester's Avatar
Anyone using an lrp sxx with a 550 4.5? If so, did you have problems?
07Forester is offline
Old 09-26-2012 | 07:49 AM
  #29904
fq06's Avatar
Can't really get a good pic of the rear but they are in the same condition. I actually recently replaced the outdrives because they were getting a little chewed up, but not the pins. Rear outdrives were worse than the front.
fq06 is offline
Old 09-26-2012 | 07:56 AM
  #29905
Oh, maybe you got me wrong. I mean the other side of the CVA-Bone, where the hinge of the complete CVA is. (the part where the pin-retainer-clip is located and the bone and the axle come together)
Cody227 is offline
Old 09-26-2012 | 07:59 AM
  #29906
fq06's Avatar
Just pulled the truck apart for a full rebuild and cleaned/lubed the part you are talking about, those pins looked just as good.
But not pulling that apart for another month
fq06 is offline
Old 09-26-2012 | 08:10 AM
  #29907
I think it's not the pin which is worn out but the cva-bone. I gets a sharp edge where the pin pushes against the bone and cuts the pin if the edge gets too sharp. I noticed that the right CVA was a lot more worn out than the left and the sharp edge is only at one side of the bone, so im pretty sure it's the accelarating which damages the cva and not the breaking. Wish i could make a pic, but my fucking camera doesnt work :/
Cody227 is offline
Old 09-26-2012 | 08:45 AM
  #29908
CraigMBA's Avatar
I would change out the whole CVA assembley - axles, pins, all of it.
CraigMBA is offline
Old 09-26-2012 | 10:10 AM
  #29909
JEFFs SC10's Avatar
hahah that's what I been using. Against my better judgement I was using that.
My buddy is gonna sell me his Hudy setup for a deal
Are you just dialing in camber only?
JEFFs SC10 is offline
Old 09-26-2012 | 10:23 AM
  #29910
dominick i.'s Avatar
i used an lrp sxx v2 tc spec with v3 software upgrade and new capacitors. with fan it worked great with a 4.5 lrp. no issues whatsoever.
dominick i. is offline
