Serpent 811E Buggy Thread >
Like Tree5Likes
Old 09-24-2012 | 07:56 AM
  #3031
what can I do to make the battery holders a wee bit bigger? I have some 5600mAH lipos that are mega tight fit and slightly too high to allow the hold to be e-clipped. Will it be possible to cut it some where to make it flex more? I don't really fancy selling off 4 sets of brand new batteries Thanks.
one-nil is offline
Old 09-24-2012 | 08:09 AM
  #3032
RCmayor's Avatar
The straps on my site allow for a little taller battery. :-)
With a thinner pack they have to be shimmed down a little to keep the battery from moving up and down. Feel free to order and if they don't work out you can send them back.
RCmayor is offline
Old 09-24-2012 | 08:38 AM
  #3033
pilotwings119's Avatar
What are some setup tips for adding rear traction on loose tracks?
pilotwings119 is offline
Old 09-24-2012 | 08:59 AM
  #3034
Thinner rear sway bar, softere rear spring, thinnere rear diff oil, Lay down rear shocks.
Magnus F is offline
Old 09-24-2012 | 03:04 PM
  #3035
Toughbeard's Avatar
Originally Posted by Maxthepersonz
Now they somewhat announced it with live R/C. Do you have any idea on a date? Will we see them by winter? Gotta have it for the indoor season
I highly doubt it will be ready for this season. you willstart seeing the prototype entering reacesmaybe but I suspect you will see the decleration next February in Nuremberg Toy Fair.
Toughbeard is offline
Old 09-24-2012 | 03:59 PM
  #3036
the buggyman's Avatar
An old but great site for setups.
http://users.telenet.be/elvo/
Great read but check out set up guide on bottom left
the buggyman is offline
Old 09-24-2012 | 06:12 PM
  #3037
RCmayor: Thanks, the straps I can bodge myself, it's really how tight the battery fits that is giving me a headache. i.e. need to remove the case from the chassis to give me enough flex to remove the battery. I guess I can try putting a piece of cloth before the battery to have a better leverage. Just hope serpent will come out with a slightly bigger battery case mould.
one-nil is offline
Old 09-24-2012 | 07:11 PM
  #3038
bigjayjay1's Avatar
Thanks from the fast shipping buddy
bigjayjay1 is offline
Old 09-24-2012 | 07:14 PM
  #3039
bigjayjay1's Avatar
Is anyone running the new 2.0 shock upgrade on the E. Wonder how this would perform being the weight and kit is overal different.
Old 09-24-2012 | 07:32 PM
  #3040
nsgland's Avatar
This will help you.
https://docs.google.com/document/d/1.../edit?hl=en_US
nsgland is offline
Old 09-24-2012 | 10:19 PM
  #3041
RCmayor's Avatar
A piece of cloth might work but it makes it fit even tighter. With a strap you take the whole door off so it is easier to get your fingers on both sides. Save yourself from a temporary bodge. :-) Ask anyone, these fit perfect and look the best.
RCmayor is offline
Old 09-26-2012 | 10:33 AM
  #3042
Default Which charger for Serpent (2 packs)
Hi guys,
I am looking for buying the Serpent 811E. Since it has two packs configuration, I am wondering whether i need a multi lines (at least 2) charger or not.
I would preferably avoid a charger requiring a power supply.
Any recommendations?
alex124 is offline
Old 09-26-2012 | 10:36 AM
  #3043
weavty1's Avatar
Originally Posted by alex124
Hi guys,
This is what I use
http://www.hobbyking.com/hobbyking/s...onnector_.html
Just make sure to use identical rated batteries when charging together, and using (running in your car) together..
I color code each pair of batteries that I buy, so that I charge them at the same time, and use them at the same time (preferably)..
weavty1 is offline
Old 09-26-2012 | 11:33 AM
  #3044
BigRon's Avatar
I use the Hitec X4 AC
http://www.amainhobbies.com/product_...-6S-6A-50W-x-4
BigRon is offline
Old 09-26-2012 | 02:52 PM
  #3045
bigjayjay1's Avatar
Hi guys,
Amians Protek Dual charger is super good I buy from them casue they back up there products great service Go Amain
