Like Tree5Likes
SC10 4x4 Thread
Old 09-10-2012 | 05:30 PM
  #29536
RCJesus's Avatar
[QUOTE=Cain;11193348]manual starting setting isn't bad at all.
I can not seem to find any suggestions in the manual for gearing of a 4000kv 4 pole motor
RCJesus is offline
Old 09-10-2012 | 05:33 PM
  #29537
Wild Cherry's Avatar
Originally Posted by JEFFs SC10
Did you forget to 'punch it' ?
Punch it is the only way I know Jeff ....
got the fastest lap for proof
I'm sure your impressed.......
Wild Cherry is offline
Old 09-10-2012 | 05:50 PM
  #29538
JEFFs SC10's Avatar
LOL
JEFFs SC10 is offline
Old 09-10-2012 | 06:27 PM
  #29539
fq06's Avatar
[QUOTE=RCJesus;11195937]
I run a 13, good place to start. You may end up at a 14 with a 4000kv 4 pole, watch temps.
fq06 is offline
Old 09-10-2012 | 06:50 PM
  #29540
I'm running a 15 with a 3800kv castle on a medium sized track.depending on the track size you will be between 12 and 16.There really is no magic pinion size.I'd start with a 14 and check temps after a few min.
xxxntwv is offline
Old 09-10-2012 | 08:07 PM
  #29541
xDIRTYx's Avatar
well shit, the rebuild kit I got has the same .2 shim in it. Think im just going to double up the shims with the new gear. Or is the .1 going to make that much of a difference?
xDIRTYx is offline
Old 09-10-2012 | 08:33 PM
  #29542
fq06's Avatar
.4 is good for now with fresh gears. Drive it for now but call AE and they will mail four .5's to you free for when the gears wear in.
fq06 is offline
Old 09-10-2012 | 08:52 PM
  #29543
Extra Tips .....
If your old shim's are already coned out ?
Save them !
Install those first, and as they were when you removed the sun gear.
Then add the extra .2mm shim on top of .
Don't forget to ditch the smaller .2mm shim on the out drive cups ....
Don't get too up set bout the .5 shim , this mod will do great and you will be happy a racer ....
Old 09-10-2012 | 09:22 PM
  #29544
ryanpatrickgore's Avatar
Originally Posted by fq06
Exactly the same outdrives. Rear gears were more worn than the front... time to replace before problems come up. Next fluid change.
All original stuff. I reshimmed the rear diff the first day I ran it. Never reshimmed the front but it's tight as day one still.
Hmmm
ryanpatrickgore is offline
Old 09-10-2012 | 09:49 PM
  #29545
xDIRTYx's Avatar
Will do tomorrow.
Extra Tips .....
Save them !
Awesome thanks for the reassurance, Thats what i ended up doing. Just finishing it up cant wait to get it out to the track tomorrow.
Im not sure what oil it had in it prior but it seemed like worn out ae grease.
Any tips for tightning the belt? Im assuming tight enough not to slip but not too tight to where it binds?
xDIRTYx is offline
Old 09-11-2012 | 09:06 AM
  #29546
Ran the truck with the exotek chassis last night for the first time. It sure is plante now and feels good. More stable and I managed to get may fasted lap yet on our new layout. Dropped from a 18.3 to a 18.2. Lol not the biggest improvement, but still...
Looking forward to more driving. Might remove my up front weight that is next to the servo next time
P.s. the truck flies great and so predictable in the air now
Old 09-11-2012 | 09:19 AM
  #29547
Cain's Avatar
what conditions are you running in ryanpatrickgore?
you definitely do get pushed around as much with the exotek chassis.
Cain is offline
Old 09-11-2012 | 09:23 AM
  #29548
vito's Avatar
got some speed in the truck back. had the belt to tight i back it off some thanks
vito is offline
Old 09-11-2012 | 09:26 AM
  #29549
Trcr. Medium bite indoor clay smooth. Big straight to a sweeper, couple big triples. S turns. Etc.. George posted a vid a few pages back with his buggy on it.
Yea nobody was pushing me I was the pusher man last night.
Haha jk
Old 09-11-2012 | 09:39 AM
  #29550
Default TRCR N/w GOLD CUP
http://www.youtube.com/watch?v=LoOl-...layer_embedded
Current TRCR layout
