The New Werks B5 .21 Racing Engine
#8476
#8479
#8481
#8483
Are you saying it was sucking air and fuel? So there are large bubbles in the fuel line? If so then yes, just like when it is running out of fuel the idle goes up before it dies because it is not getting enough fuel to maintain the idle. There can be other causes but it sounds like you should look at your fuel and pressure line first if everything was fine before today IMO.
#8484
#8485
I doubt it, if everything was fine the last 3 tanks that you ran, how did it get an air leak all of a sudden? Much more likely that the weather conditions changed and the tune is simply too lean now. If you can get some help with the tuning part at your local shop, it will probably help to have them show you how to tune the engine etc.
#8486
#8488
it started right up fine an i gave it some gas and it just speeds up hight and wont come down . i hope it not my radio its a dx 3 c with lipo rx pack. iam gooing to have my shop look it over. and the last time i tryed it out she sound fine to get the fule out of it.
#8490
If the carb slide is fully returning to the recommended idle gap, richen the LSN 1/4 turn. Heck, richen it 1/2 turn. It probably won't be tuned, but if your idle problem goes away, your home.
You'll feel better if YOU find the problem rather than your shop.
63Likes
