RC10B4.1 FT/WC
Old 09-04-2012 | 03:53 PM
  #19876
Matt Trimmings's Avatar
Where were you at with the 72t spur?
Matt Trimmings is offline
Old 09-04-2012 | 03:58 PM
  #19877
mxracer458's Avatar
72/31-22
mxracer458 is offline
Old 09-04-2012 | 04:05 PM
  #19878
RC_nooberton's Avatar
Originally Posted by mxracer458
72/31-22
Is that in blinky mode or with timing? Sorry to horn in your convo, just trying to learns as much as I can.
RC_nooberton is offline
Old 09-04-2012 | 04:06 PM
  #19879
mxracer458's Avatar
17.5 blinky,I run at weatcoast,sdrc mainly
Old 09-04-2012 | 04:11 PM
  #19880
Venom1836's Avatar
Originally Posted by Bob Barry
2.5 deg gives you the illusion of more traction going through a turn but it's actually less, which can be good. It flows smoother so there's no hard 'grab' and square up like you get with more toe. And since you gain that traction while rotating, you gain more corner speed, which translates into forward bite coming out of the turn if you are smooth. It also slides the wheels back ever so slightly too.
What it comes down to is does your car rotate through the turns properly and do you have enough forward bite to clear the hardest jumps (like where there's a short run up). Again this is only when your car is on the right tires. I say this because tires are 90% of your setup
I am still running the Proline Tires that came with the kit.
i just can not turn sharp enough.
The most common front tires at my track are green or blue Barcodes up front.
If tires dont solve my issue of not being able to turn sharp enough then I will try 2.5
Do you think it is my tires?
Venom1836 is offline
Old 09-04-2012 | 04:12 PM
  #19881
And no end bell timing either?
Old 09-04-2012 | 04:13 PM
  #19882
B.A. Racer's Avatar
It sure sounds like tires to me...Are you racing indoor or outdoor? And what is the dirt like?
B.A. Racer is offline
Old 09-04-2012 | 04:14 PM
  #19883
ilanstylz's Avatar
I am currently running 35/75 with end bell timing turned all the way up on my revtech 17.5, it has great top end but looking for a little bit more low end without sacrificing to much top speed. Would a 32/75 work or should I go 33 or 34?
ilanstylz is offline
Old 09-04-2012 | 04:15 PM
  #19884
End bell timing can be adjusted for blinky classes. I am about 30-35 degrees on my reedy 17.5
Old 09-04-2012 | 04:22 PM
  #19885
-WHEELMAN-'s Avatar
72/31-22
Need to be at least 72/32 to keep up at West Coast in the stock class! 75 spur is the wrong way!! Try going back to 72 and carry more speed so you don't need as much bottom end!
-WHEELMAN- is offline
Old 09-04-2012 | 04:23 PM
  #19886
mxracer458's Avatar
1 dot from being maxed out on the lrp,lrp motors are alittle differsnt
Old 09-04-2012 | 04:26 PM
  #19887
mxracer458's Avatar
If I was any good I could do that....I asked Ron what Motter was running and that's what he told me,I think it's just as fast with better bottom,took 1st in stock buggy at sdrc Friday night.cant wait to try out the Redlands tracks!
Old 09-04-2012 | 05:01 PM
  #19888
Thanks again for the good information guys.
  #19889
not being a dick when I say this, but NO ONE on here can tell you that unless they race on your track. We can offer suggestions for what should work, but that's about it. If guys are running barcodes in the front, there's a good chance your out to lunch as far as tires. Take a few minutes and ask the local fast guys what tires and foams you should have and then start from there. Once you get your car with the right tires, see if one of them will take your car for a few laps.... they will be able to tell you almost instantly if you are in the ball park or out to lunch.
Bob Barry is offline
Old 09-04-2012 | 05:11 PM
  #19890
I'd like to know as well as I've got a 17.5 Rev-tech I'm considering running in stock class. I'm assuming your temps are ok?
