RC10B4.1 FT/WC
Old 09-01-2012 | 11:13 AM
  #19726
Wildcat1971's Avatar
Tech Prophet
Originally Posted by jdeadman
+1 on the dremel I have also used Ca glue on the tip of the screw driver. let it set for a few moments then undo the screw to get the screw off just heat up the screw with a torch and the CA comes off
Also I have found some 5/64 hex screws in the 4-40 thread in my old screw pile. Don't know where they came from but never have a problem.
I would try the ca thing. I still have wheels with axles attached in my shop because the dremal idea didnt work.
Wildcat1971 is offline
Old 09-01-2012 | 11:20 AM
  #19727
D.Martijn's Avatar
I stripped the middle screw of the top plate where the blue countersunk washers are,
Had no choice to dremel the screw and also a little bit of the countersunk washer
I looked for a screw extractor but all the shops here don't seem to have those...
are the screw extractors good? what seize should I get (going to buy one on ebay)
D.Martijn is offline
Old 09-01-2012 | 11:26 AM
  #19728
chris c's Avatar
These are the only ones that really work
Mine has saved the day for tons of people
http://mobile.walmart.com/m/phoenix;...actor/15162110
chris c is offline
Old 09-01-2012 | 12:03 PM
  #19729
D.Martijn's Avatar
Does walmart ship to Belgium?
Old 09-01-2012 | 01:27 PM
  #19730
chris c's Avatar
I am not sure if they do but someone has to sell similar there
chris c is offline
Old 09-01-2012 | 01:36 PM
  #19731
CnR's Avatar
CnR
Default Finally Finished
Started on it about a month ago. finally finished along with the new avid triad slipper. I also have a custom painted body on the way. cant wait to get it out on the track.
Attached Thumbnails RC10B4.1 FT/WC-photo%5B12%5D.jpg
CnR is offline
Old 09-01-2012 | 02:00 PM
  #19732
D.Martijn's Avatar
Nice, I actualy like the blue body
Old 09-01-2012 | 02:09 PM
  #19733
CnR's Avatar
CnR
Thanks. doesn't come out in the pic very well but I sprayed a layer of silver so it has a lil sparkle in it.
has anyone tried the avid triad slipper ?
Cant wait for the big bores to come out !!
CnR is offline
Old 09-01-2012 | 02:10 PM
  #19734
Tech Prophet
yeah, I used to be really into my paint jobs, but I am old and lazy now. I might just start doing 1 color bodies.
Old 09-01-2012 | 02:42 PM
  #19735
RT3's Avatar
RT3
Hey guys. I recently purchased the Avid steering rack and was trying to install it. When installing the steering rack on my b4.1, am I supposed to use the bearings from my b4.1 kit? I noticed some holes where they could go, but they seemed like a very tight fit (and I would have to jam them in there). Also, should I be using the plastic steering brace that comes with with stock steering rack (the small plastic brace that goes under the steering rack? In other words, what pieces from my b4.1 do I need to complete the install. Thanks!
RT3 is offline
Old 09-01-2012 | 03:50 PM
  #19736
Originally Posted by 3srcracing
This is what I did:
Grabbed a grinder
Piece of sand paper
Pain (optional)
and a ball stud with a hex on the bottom to tighten it.
Then continue to grind of the ball end until it leaves you a hex. You then get the sane paper to sand it to make it smooth. Since it will be rough gray if you pain some primer and paint (use the tape to tape off the threads) and then paint it if you wish. You now have a hex screw for your front axle.
Oh, that is a great idea Cooper. Are you sure someone that you use to race with didn't come up with that idea? Then maybe that someone used nate's dad's dremel to make them. Maybe it was on his last day at the track before he moved?
R.Shackleford is offline
Old 09-01-2012 | 04:39 PM
  #19737
RC_nooberton's Avatar
I just put the Avid steering rack in my SC10. My SC10 is RTR though so I don't bearings (ordered them) but bushings. The bushings/bearings do go into the large holes on the 2 Avid pieces although I lost one of my bushings and it didn't seem to make a difference. And yes you re-use the plastic brace from the old rack too.
Some will advise you to use thread-lock on the upside down screws, but be very careful with that if you use it at all. Thread-lock in the wrong places will cause binding - the last thing you want.
Hope that helps a little. You can do it.
RC_nooberton is offline
Old 09-01-2012 | 05:00 PM
  #19738
FACTORYBUTNOT's Avatar
The new Avid slipper is great...it's surprising at how much better it is
FACTORYBUTNOT is offline
Old 09-01-2012 | 05:14 PM
  #19739
Tech Prophet
please describe the difference
Old 09-01-2012 | 05:28 PM
  #19740
YankeeFan123's Avatar
Factorybutnot describes it several pages back on the testing he did with his buddy.
YankeeFan123 is offline
