Ask Steve "The Evicerator" Weiss
#7082
Steve,
Sent you a message on myspace. So my question is, in 17.5 / 13.5 how much of a difference is there with the 12.3mm 1300+ rotors? Does this rotor also work well for mod?
#7083
The Evicerator
Sorry I don't get onto myspace all that much anymore!
The 1300+ rotors make a big difference if you've got a weak rotor... especially in the "limited" classes like 17.5/13.5.
The rotors work well in modified as well.
#7084
Steve,
Cheers for the info.
MiCk B. :-)
MiCk B. :-)
Hi Mick,
The gap isn't something to really worry about, it's basically just a tollerance issue with the sleeve that plays no performance role.
If you are concerned about hte sleeve spinning you can simply slide the sleeve off and put a strip of decal down on the lamination to tighten up the interference fit when you slide the sleeve back on.
#7085
Can anyone tell me what the motor timing is set at on an old Novak ss 13.5t motor please? The reason i ask is i have a new generation software driven speedo and don't want to cook the motor. I also notice that if i loosen the endbell screws there is a small amount of adjustment any ideas how much in degrees? without timing marks in running blind.
#7086
The Evicerator
#7087
Those motors are set to 30 degrees internally. I would just leave the timing there... there is a lot of mis-information about what "zero" degrees of timing is in a brushless motor and no one actually runs their motor with zero timing. Generally, the novaks are among the lowest timed motors.
#7089
Hi Steve...I need some help
How can I get my car to rotate more? With Solaris Hard spec tires my car rotates OK, but I raced with the Solaris SP40 and the rear end seems to be more stuck.
I attached my setup sheet...I was thinking of trying laying the rear shocks down 1 hole to #2 and using less camber in the rear, maybe -1.5 in the rear.
For the T3 2011, which way do Ackermann spacers work? More shims = more rotation? I'm running 1mm Ackerman spacers.
One last question...in the future when I bolt in a mod motor - do you hit the brakes at the end of the straight for the turn in or do you just let off and turn in? If you don't use the brakes how far into the straight do you keep on the throttle?
I bet the pumpkins wont even be orange this year
